Question about Panasonic HDC-DX1 DVD Camcorder
So i have a good one for you. I am a network engineer and i have not been able to solve this. I have a panasonic hdc-dx1 camcorder. I am using Corel Video Studio Pro x3 and has the capability to capture from a AVCHD camcorder i checked. Which happens to be my camcorder. I cannot find which cable to hook it up to the pc to capture the video. I read some where that you use the firewire cable (IEEE1394) but the camcorder does not have that connection. I will pay to have this issue solved. Thank You
  • 5 more comments
  • samgiray Sep 13, 2010
    Thanks for the reply, corel video studio captures videos froom avchd cameras which is mine. Are you saying my hdc-dx1 camera doesnt allow it ?
    This Panasonic HDC-DX1 is a HD camcorder and doesnt record in a format a normal dvd player can read ! Corel Video Studio Pro X3 captures directly from AVCHD camcorder which is this one. SO no writing on a DVD. You initiate the record from the Video Studio Pro X3. I am asking which cable you need to use to capture the video. Or does this camcorder support capturing. Thanks
    Very nice answer sir, so the camcorder has a usb, HDMI, Component, S video, analog, outputs. Everything i can need. But corel captures directly from a AVCHD camcorder, so i am wondering if this camcorder can do that. I am suppose to plug a cable in and corel notices it. Then i just hit capture in corel, and the camcorder turns into a expensive webcam so to speak. Maybe this AVCHD camcorder cant do this, i am not sure. I have read it can and it cant so i am not sure what to do
    ohh also if you plug in the usb, it is just for getting the pictures you took that are on the SDcard in the camcorder. No other function will work in that mode. And you cant transfer the burned dvds on the camcorder thru the usb cable
  • samgiray Sep 14, 2010
    Thanks Man. Thats is what it has come to. I have seen the blackmagic but it has USB3.0 which i dont have. Is there a hdmi capture device that is usb 2.0 or firewire thanks. I have seen Hauppauge, AVerMeda they make external ones with component connection. Is there a external one that is hdmi and usb 2.0 or firewire thanks again
    thanks again, component it is. I will be going to locations with a hd camera hooked to the laptop so wont be able to be a desktop. Thanks again
  • samgiray Sep 15, 2010
    thanks for answering my question rather than saying just technical words
  • 977 Answers
Hi!
I think that in this case, as your camera doesn't have a firewire connection (as you mentioned), the best solution would be to use it's HDMI connection, in combination with a HDMI capturing device (for example: Blackmagic Design's Intensity/Intensity Pro) and a special video capturing software such as Blackmagic's own software, Adobe Premiere Pro, the freeware VirtualDub (a little complex to use and configure) or any other HD supported video capturing software of your choice.
Hope this helps,
Pelu.
Posted on Sep 14, 2010
  • Ran Kedar
    Ran Kedar Sep 14, 2010
    If possible (i.e. You're using a desktop PC/Mac, rather than a laptop), I'd recommend you buying the internal Intensity Pro, which connects through a PCI-E connection... Such devices of USB2.0/FireWire connection are rare, as the throughput required is generally too high for USB or Firewire.
    I did found Grass Valley ADVC-HD50 that you can use - but, as you can see, it's MUCH more expensive!
    Best regards,
    Pelu.
  • Ran Kedar
    You're welcome! If you found my assistance/solution helpful, you're kindly requested to accept it... Thanks! :)
  • Panasonic Master
  • 12,061 Answers
Right well, if you have a USB output on your camera, then you can get converters for that firewire, you can get USB 2, to Firewire, as an aside Firewire IS USB, more or less, just differing plugs/sockets. IEEE 1394 standard.
Also if your camera has a Video/Audio out, either HDMI, Component, or Composite, then anyone of these too can be used to get Video/Audio into the PC. With suitable input hardware, which usually is a USB Video Dongle, or TV Tuner card, these take the Output from the camera, into the PC, Then a signal can be streamed to the PC, and digitized for use in Corel.
It also may be possible to use Corel directly, with the USB Dongle(s), as all installing the dongle does, is, it install a Driver, Now, Corel should be able to use that.
Otherwise one would still be able to use it to digitize the incoming signal, and save it as a suitable file, for later use in Corel.
Have a look below at the Firewire to USB dongle.
http://shop.ebay.com/i.html?_nkw=firewire+to+usb&_sacat=0&_odkw=htc+evo+4g&_osacat=0&_trksid=p3286.c0.m270.l1313
Have a look here below, for the Video input dongle.
http://shop.ebay.com/i.html?_nkw=video+in+usb&_sacat=0&_odkw=firewire+to+usb&_osacat=0&_trksid=p3286.c0.m270.l1313
Posted on Sep 13, 2010
  • 10,594 Answers
DVD camcorder is not suppose to hook with PC as movie files can easily be transferred by putting recorded dvd disc from camcorder in dvd rom of computer.
Make sure to finalize dvd after recording in camcorder so computer or other dvd player can read its data.
IEEE1394 cable used with hard drive camcorder or those used Video-8 or MiniDV tapes as data storage medium.
Thanks.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 13, 2010
    No, I'm not saying anything about compatibility.
    Does camcorder has USB port?
    Plug it with computer to transfer movie files but only finalized dvd files can be transferred in computer.
    DVD Camcorder records files on dvd disc as raw data that can only be readout through camcorder and can not be transferred in computer, when recording completed, that raw data dvd disc needs to be finalized in camcorder while powering it by ac power charger to get finalize option in menu then recorded dvd disc becomes valid dvd for other dvd rom, player etc
    Thanks
    Thanks
Power Suply not connecting
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Jan 28, 2011 | Panasonic HDC-DX1 DVD Camcorder
Tip
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Panasonic HDC camcorder family has a great number of High-Definition Camcorders that satisfy different people who want to record their interesting daily life, now, You can check the list of popular Panasonic HDC series camcorder as follows:
Panasonic HDC-SD Series: Panasonic HDC-SD9, HDC-SD10, HDC-SD60, HDC-SD100, HDC-SD200, HDC-SD700, etc.
Panasonic HDC-HS Series: Panasonic HDC-HS250, HDC-HS300, HDC-SD60, HDC-HS200, HDC HS100, HDC-HS700, etc.
Panasonic HDC-TM Series: Panasonic HDC-TM10, HDC-TM20, HDC-TM60, HDC-TM50, HDC-TM30, HDC-TM200, HDC-TM300, HDC-TM700, etc.
Most of Panasonic HDC Series Camcorders record video in AVCHD MTS/M2TS files, for example, Panasonic HDC-SD9 records 1080i 17Mbps video in M2TS files; Panasonic HDC-SD700, Panasonic HDC-HS700,
Panasonic HDC-TM700, these three types store videos in MTS format and all offer Full HD 1,920x1,080-pixel resolution at 50 frames per second. For Mac users, if you cannot import Panasonic HDC video to Mac to enjoy, or cannot directly edit Panasonic AVCHD MTS/M2TS files in iMovie, FCP, FCE, you need to convert Panasonic HDC videos to MOV, MP4, 3GP, M4V, H.264 for Mac and then you can edit converted AVCHD MTS/M2TS video with iMovie, iTunes, FCP, FCE, etc.
Mac Panasonic HDC Video Converter, a professional AVCHD Converter, is designed for converting videos collected from Camcorder Panasonic, Canon, Sony, etc to MP4, MOV, MPEG, 3GP, M4V, AVI, etc to Mac, then you can play AVCHD MTS/M2TS, videos on Mac, iPad, iPod, iPhone, PSP, Blackberry, and any other mobile phones.
How to convert and edit Panasonic HDC video to Mac?
Step1: Import Panasonic HDC Video to AVCHD Converter for Mac
Click "Add File" to upload your Panasonic HDC video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac, iMovie, FCP
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, iMovie, iTunes, iDVD, FCP, FCE, etc.
Step3: Convert Panasonic HDC Video to Mac, iMovie
Click "Start" button to convert Panasonic AVCHD MTS/M2TS files for Mac. After conversion finished, you can enjoy converted MTS/M2TS files on Mac or edit these converted AVCHD video with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 19, 2010 | Computers & Internet
Tip
Best HD Camcorder for Mac, iMovie, iMovie? 08, iMovie? 09
Recording daily life and interesting things with a HD camcorder becomes a trend for our people. They like to share these digital camcorder videos on Mac or PC with family and friends. However, selecting a good digital camcorder for Mac is not easy for green hand. Maybe more tips need paying attention, for example, the types of your camcorder and Mac, the version of iMovie on Mac, Mac and PC compability with digital camcorder and so on.
iMovie has been a Mac OS X only application bundled in the iLife suite of Macintosh applications since iMovie3. From 2007 to 2010, Apple developed iMovie to iMovie' 08, iMovie' 09, and iMovie for iPhone and iPod Touch. Luckily, iMovie' 08, iMovie' 09 are designed to work with a wide range of digital video devices and formats, including tape-based(use a FireWire cable, also known as IEEE 1394 or i.Link) and the latest tapeless camcorders that record to flash memory, a hard disk drive(HDD), or DVD media.
A list of Digital Camcorders Compatible with iMovie' 08, iMovie' 09 on Mac OS X
NTSC Camcorders(a video format used in North America, Central America, Japan, and parts of South America)
Canon: DC20, DC50, DC220, DC230, FS10, FS11, FS100, HF10, HF11, HF100, HG10, HG20, HG21, HR10.
JVC: GZ-HD10, GZ-HD30, GZ-HD40, GZ-MG330, GZ-MG67, GZ-MG255, GZ-MG555U, GZ-MG505U.
Panasonic: HDC-DX1, HDC-SD5, HDC-SD9, HDC-SD20, HDC-SD200, HDC-HS9, HDC-HS20, HDC-HS100, HDC-HS200, HDC-HS300, HDC-SX5, SDR-H50, SDR-H60, SDR-H200, SDR-S10
Sony: HDR-CX11, HDR-CX12, HDR-SR1, HDR-SR7, HDR-SR11, HDR-TG1, DCR-SR82, DCR-SR200, DCR-DVD308, DCR-DVD508, DCR-DVD403.
PAL Camcorders(a video format used in Europe, Africa, the Middle East, most of Asia, and parts of South America)
Canon: DC50E, DC220E, DC330E, FS10E, FS100E, HF11E, HF100E, HG10E, HG20E, HG21E.
JVC: GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-MG255, GZ-MG67, GZ-MG155, GZ-MG330.
Panasonic: HDC-DX1, HDC-SD9, HDC-SD200, HDC-TM20, HDC-TM300, HDC-HS20, HDC-HS200, HDC-HS300, SDR-H79, SDR-H60, SDR-S15, SDR-S26.
Sony: DCR-DVD908E, HDR-CX11E, HDR-CX12, HDR-SR1E, DCR-SR5E, HDR-SR12E, HDR-TG1E, HDR-CX7E, HDR-UX20E, DCR-SR82E, DCR-SR100E, DCR-SR300E.
Although iMovie' 08, iMovie' 09 on Mac OS work with most of HD digital camcorders using MPEG-2 (standard definition), MPEG-4, AVCHD, and H.264 formats, not all tapeless camcorders are compatible with iMovie' 08, iMovie '09 because of the wide range of media types and the different ways manufacturers store video on these media types.
How to fix it? To meet people editing AVCHD, MOD files with iMovie, enjoying HD camcorder video on Mac, a powerful HD Video Converter for Mac is specially designed for people who need to convert AVCHD MTS/M2TS, MOD, TS, TOD, MKV files to iMovie MP4, MOV, DV for better editing. Besides, that Mac HD Converter is also the very choice to convert HD video like TP, TRP, M5S, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD to Mac application: iTunes, iDVD, FCP, FCE, etc.
Related: Click here to see more info of AVCHD Converter for Mac for people to convert AVCHD files to Mac iMovie, iPod, iPad, iPhones, PSP, BlackBerry, Zune and other handy device.
How to Convert AVCHD MTS/M2TS to Mac formats?
on Sep 21, 2010 | Computers & Internet
Can I use 32gb sdhc card on Panasonic hdc-sd1 camcorder
The camcorder only supports 4GB SDHC cards.
Regards
Jun 30, 2009 | Panasonic HDC-DX1 DVD Camcorder
Camera will not turn on
Push the reset button behind the screen????
Dec 31, 2008 | Panasonic HDC-DX1 DVD Camcorder
Transfer footage from DVD to Computer for editing
I use ISO Buster to read the AVCHD footage into my computer and then edit with Pinnacle Studio. With ISO Buster, you place the 3" AVCHD DVD into your regular DVD Rom drive on your computer and it will rip the raw files directly from the disk. You cannot transfer the movies from the DX1 to Pinnacle or any other editor using the USB cable.
Mar 18, 2008 | Panasonic HDC-DX1 DVD Camcorder
Panasonic HDC-DX1
What did you try so far? Maybe this user review (not mine) has a bit of an answer?
Feb 01, 2008 | Panasonic HDC-SD1 Camcorder
Panasonic HDC-DX1 DVD Camcorder Logo
75 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
