Question about OCE 3140 Copier
Oce CM3522 color copier won't print all of a sudden. It has arrows pointing to all four imaging units to be replaced but WE JUST DID THAT LESS THAN A WEEK AGO. Anyone know how to bypass the error message?
  • 149 Answers
There is no bypass on this machine, the counts are reset by the machine thru fuses in the imaging units. If this is in error, there is a bigger problem, pls call a tech
Posted on Oct 05, 2010
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
I cannot get my oce fx3000 printer to print
After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
Oct 08, 2014 | Canon Genuine Oce Imagistics Fx3000...
OCE plotwave 300, error code 22509. Printer won't print.
PLC Connection lost. Get your Oce technician to upgrade you to the latest supported software level.
Oct 31, 2011 | OCE 3140 Copier
How do you reset the oce cm3522 fuser assembly error code
Only a qualified tech can do this. It's a safety feature since the fusers run hot and the maker's don't want their machines to start fires.
Feb 03, 2011 | Office Equipment & Supplies
Halftones on Oce Variolink 2822C all in one copier
Unfortunately for you, as color copiers have gotten better, so have the dpi, and there is no low resolution. Have you tried changing the resolution of your original file in an image program like adobe.
Jan 29, 2010 | Office Equipment & Supplies
How to change OCE CM3522 imaging belt
transfer belt or imaging unit? First, you need a new one
Nov 30, 2009 | OCE Office Equipment & Supplies
We have a CM3522 printer. Just changed the black
check the consumables to see if the imaging unit needs to be changed.
Oct 20, 2009 | Office Equipment & Supplies
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
235 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
