Question about HP LaserJet 3330 All-In-One Printer
I cannot FAX anything because I keep getting "memory low press enter" when I try to FAX. How can I fix this?
Deleting faxes from memory
Use this procedure only if you are concerned someone else has access
to your product and will try to reprint faxes from the reprint memory.
CAUTION In addition to clearing the reprint memory, this procedure clears any fax
currently being sent, unsent faxes pending redial, faxes scheduled to be
sent at a future time, and faxes not printed or forwarded.
To delete faxes from memory
1 Press menu/enter.
2 Press > once to display Fax Functions and press menu/enter.
3 Use the button to select Clear Saved Faxs, and press
menu/enter.
4 Press menu/enter to confirm the deletion.
Posted on Sep 13, 2010
My 3050 suddenly refused to fax stating the memory is low. It has worked fine for several years. What is the problem today?
You need to clear the stuff out of memory.
Press the menu/enter button on the control panel.
Press the > button once to select Fax functions , and then press menu/enter .
Press to select Clear saved faxes , and then press menu/enter .
Press menu/enter to confirm deletion.
Jul 07, 2011 | HP LaserJet 3055 All-In-One Printer
Memory low on hp laser jet 3050. Please advise how to fix the problem. Thank you
solution: 1. Clear the fax memory. Here are the steps to clear the fax memory: a. Press the menu/enter button on the control panel. b. Press the > button once to select Fax functions , and then press menu/enter . c. Press or > to select Clear saved faxes , and then press menu/enter . d. Press menu/enter to confirm the deletion. NOTE: In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded. 2. Enable the settings to print directly to the printer. Perform the following from the PC that has the printer driver installed: a. Click Start , Printers and Faxes , and check for the driver listed for the printer. b. Right-click the printer driver, and select Properties . c. Then click the Advanced tab, and check the print directly to the printer option. Click Apply , and thenOK . After performing each of these troubleshooting steps, try doing a print job and check for the results.
Jun 10, 2011 | HP LaserJet 3050 All-In-One Printer
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
Hi I am getting an error message 232 on my HP Laserjet 3055 - it says on the screen that it is low on memory but I can't find where to reset the memory if this is the problem. Thank you
Perform the following to clear the fax memory:
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
As far as I know, there is no option to turn this Fax Caching option off.
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
Hp laser jet 3050 memory low does not allow me to receive faxes or even photocopy? What can I try to fix this problem?
Perhaps you could clear the fax memory.
Dec 03, 2009 | HP LaserJet 3050 All-In-One Printer
My LJ 3055, it says memory is low. Pls let me know how to solve it
This can happen if your fax memory is full.
Clearing the fax memory Perform the following to clear the fax memory:
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Retreive faxes from memory
This is normally a low toner situation. You need a new toner cartridge. In the meantime, do the following:
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Nov 07, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Problem with fax Memory
This could be very simple. Check to be EXTRA sure that your USB line is NOT plugged into the fax line. (There's a little phone icon). That's what happened to me....boy am i dumb!
Oct 02, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP LaserJet 3330 All-In-One Printer Logo
660 people viewed this question
Seeker5211
Seeker5211
