Question about Garden
Type lnt-2 120v60hz 8.0A 14"bar 097570-01/chain 091374-02s
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: remington 14'' limb&trim..chain questions
The honest answer to will any 14" chain fit is no! It is "YES" if it has 50 drive links, a 3/8 pitch, and a gauge of 0.050 will; provided you are using the original bar or a suitable substitute. Manufacturers almost never tell you these numbers. They want you to purchase replacements from them. Any merchant, that sells chain, given (50, 3/8, 0.050) this information can fabricate a replacement chain and unless you tell them differently it will most likely be a green chain. A local merchant will save shipping and handling fees. I enjoyed this exercise in painting with text. I hope you have a better understanding of your question. Thank You.
If you go here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Input "Remington; LNT-2; 14"; All; All; All"
It tells you there are 50 drive links (the important part of length, ±1 drive link may still be 14” but will not fit); it has a pitch of 3/8 (there are other pitches available); it has a gauge of 0.050 (0.043 & 0.058 also common). If you read the Triangular information tags you will see different chains have more or less chance of kickback. I will not purchase anything with a green tag but have been using chainsaws since 1980 and wear full PPE. I hope this clarifies this part of your question.
Your OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
A much better Remington explanation of chain installation.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
My explanation/example (gas but similar). The repair is the same; burrs are often created when the chain comes off at speed.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
What kind of oil is used for a 12'' 115v elec chainsaw model lnt-2
Hi, any brand of bar and chain oil is fine. Hope this helps, regards Phil.
Jun 14, 2011 | Remington Electric Chain Saw
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I have a Remington pole saw Model 108526-01 Type LNT-2 10" BAR-097567-01/CHAIN -091371S It works very well but the chain does not cut anymore. Where can I get the replacement. I do not have the...
3 choices for a chain can be found on the link. Your current chain is likely the green one. Any local chain outlet given your chain as a sample can fabricate a new chain in 5 - 10 Minutes.
Remington, LNT-2, 10", All, All, All
Oregon does not offer a replacement bar. I think yours is solid nose bar and may be difficult to find outside of RemingtonPower.
RemingtonPower is no longer in production. The name was purchased by MTD, they are providing some parts here.
PartsFor.com
http://www.partsfor.com/
They have taken down to link to the Illustrated Parts Breakdowns for RemingtonPower and the part numbers you provided do not cross to anything at the new parts provider. Sorry I could be of more help. There is a phone number at the new parts supplier. They may be able to supply a current part number.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 31, 2010 | Remington Polesaw Wizard
Remington 14'' limb&trim..chain questions
If you go here:
Your OM
Lou
Mar 27, 2010 | Desa International Remington 14" Electric...
How do I get a replacement chain for my Remington 8'' Pole Saw (Part No 104301-S)
That is not a valid part number (also 8SC NLA Remington & Master). If the pole saw is an RPS96 (LNT-2) with the original or equivilent 8" bar, YOU can make an informed decision based on the following:
"Remington; LNT-2; 8"; All; All; All". You are presented with 3 choices on the following table.
The above results are for an original or equivalent (34 drive link chain to fit) 8" bar. Only YOU can determine your level of expertise, how much risk you are willing to assume and choose one of part numbers listed. Once you make your choice it can be found on the Internet or through local merchants. If your local outlet does not handle Oregon your choice can easily be converted to other chain manufacturers part numbers. I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
Lou
Mar 22, 2010 | Remington Electric Pole Saw
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington Garden
What type of oil do a Remington 14" 1.5 electric chain saw use
Use any commercial bar oil. It is available at most home centers and hardware stores. I use the Ace Hardware brand. Bar oil contains tackifiers to attempt to keep it on the bar and chain, the parts that need lubrication. HTH
Lou
Oct 10, 2009 | Remington 16" Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
