Question about Acer Aspire One AOD150-1920 Netbook
Windows doesn' boot -- just keeps "loading" - Acer Aspire One AOD150-1920 Netbook
  • 393 Answers
Update the bios thats it's
Posted on Sep 14, 2010
  • Shahzad Iqbal
    Shahzad Iqbal Sep 14, 2010
    update bios or format the hdd if not work then change hdd
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
What's your problem?- CANT LOAD WINDOWS 7 ON LATITUDE E6420
it comes preinstalled with windows 7, what error message are you receiving while attempting install? if you mean it doesn't load the actual OS after booting, what error are you getting? does start up repair attempt to run?
Jul 03, 2012 | Dell Latitude E6420 PC Notebook
I have an SATA drive attached and it will let me install windows to it but when it restarts to run windows it doesn't seem to be able to load windows from that drive and wants to install windows over...
This may be a boot order issue; your BIOS is probably set to boot CD before HD, so as long as you keep the CD in the tray, it'll try to run that first.
Aug 11, 2011 | MSI 661FM3-V Motherboard
Toshiba tecra m1 pc.. boot cycle keeps recycling... the windows logo appears then it auto restarts... will not finish loading windows xp same thing happens when i try to boot in safe mode.. any of the...
If it's rebooting when trying to boot into safe mode as well, have you tried "Last Known Good Configuration"? Press F8 like you do to go into Safe Mode, and choose this instead.
If this doesn't work, on the F8 menu, you can disable automatic restart. This will cause Windows to hang instead of automatically rebooting when it encounters an error. With any luck, it will display a STOP error for you. If you get this, comment with the error and I'll be happy to look that up for you.
If this helps, please give a positive rating.
Jul 05, 2011 | Toshiba Tecra M1 PC Laptops
My Presario CQ60 is stuck in recovery manager mode. I keeps going to startup repair.
Problems starting up a PC can be tricky to fix, since Windows hasn't had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair can prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from starting.
Startup Repair is designed to start automatically if Windows detects a startup problem. For more information about using Startup Repair, and what to do if it doesn't start automatically
here is my solution... when you boot your window when you're middle in dos loading press F8 and select boot in safe mode... then when you are in windows click start --> all programs ---> accessories---> sytem tools ---> system restore... hope you back up your windows.... try to restore your window in earlier time...
HOPE IT HELPS AND GOD BLESS
Jun 27, 2011 | Compaq Presario CQ56-115DX Laptop
In acer laptop i am getting blue screen error code is 0000000007
Try to restart the computer in Last known good configuration from the Advance boot options by restarting the computer using F8 key continuously.
If doesn't work then put in the Windows CD.
If Windows XP :
Restart the computer and keep tapping F12.
From boot menu highlight CD/DVD or IDE CD ROM or USB CD ROM.
Keep on pressing enter on it until get the screen loading files.
Then on the first Welcome page press "R"
If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
Enter the Admin password if dont have any password then leave blank and press enter.
Then type the command chkdsk drive /p /r
(drive is the partition on which windows is installed, C: or D:)
It will take around 30 to 45 mins to complete then restart the computer.
Jun 13, 2011 | Computers & Internet
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
T2 AE1
Make sure the cmos setup is set to try booting from the CDROM. There are various methods to access cmos setup...but usually you need to press either the Delete key, or F10 or F12 right after turning on the power.
If it won't boot from the CDROM, the problem is is more likely to be in the power supply or motherboard than the hard drive.
Jan 13, 2008 | ASUS Terminator 2 AE1 (T2AE1) Barebone
Acer Aspire One AOD150-1920 Netbook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
