Question about Refrigerators
Good evening, iI HAVE A QUESTION ABOUT THE G.E. REPLACEMENT ICE MAKER . THE NEWER STYLE I/M 6. IS ANYONE ELSE OUT THERE HAVING PROBLEMS WITH THIS THING SHUTTING OFF? THIS ONE DOESN'T HAVE THE GOOD OLD WAND THAT CYCLES UP AND DOWN, IT HAS THE ARM THAT MOVES IN AND OUT HORIZONTALLY. IT SEEMS LIKE INSTEAD OF STOPPING IT IS PUSHING THE ICE OUT OF THE WAY AND CONTINUES TO MAKE ICE. I'VE TRIED THREE ICE MAKERS AND THEY'RE ALL DOING THE SAME THING. I APPRECIATE SOME INPUT, THANKS , FRED.
  • papaduck2008 Sep 14, 2010
    HAS ANYONE ELSE OUT THERE RUN ACROSS THIS PROBLEM BEFORE I CONTACT G.E.
    yes it was about as i expected, it good to know someone else shares my opinion of this imported garbage. [hey wasn't imported garbage a song by SPIRIT?]..........just kidding i know it was fresh garbage. have a good one. thanks. Fred
  • 734 Answers
Hi There,
I feel badly that no one has covered this for you yet. I'll just go after it with logic because it makes me keep thinking of that scene in the movie "9 to 5" when the printer won't stop and Jane Fonda's fraking out in her library lady glasses. :)
It's got to be mechanical or electrical or both. The arm is supposed to recognize contact with the ice, whether through the arm touching the ice and being moved and told to stop, or the ice touching it sends a temperature that can only be sensed by contact with the ice.
On the other end, inside the module where the arm originates, the arm has to trip a switch that disengages the command to make ice, or a sensor there has to react to the temperature received through the arm by contact with the ice and throw a switch to command no ice be made.
Common sense says the most likely problem is the module, and that a faukty run of manufacturing happened at a GM USA plant or an out sourced plant is shipping junk that GE's packaging because you've been through several.
I think you need to have GE replace however many it takes to get a good one and tell them to send someone smarter than a rock to China to get them on track.
Best Regards,
The Thinker
Posted on Sep 14, 2010
    Top Expert:
  • Refrigerators Master
  • 75,797 Answers
We have not seen any other posts of problems like yours, suggest u contact GE about this and see what they recommend to do.
Posted on Sep 13, 2010
  • 2,272 Answers
The arm is called auger and its controlled by the motor.If the motor is got malfunctioned then it will run the auger non stop and this will cause the ice to dispense again n again.But the other possibility is the water fill valve and solenoid.If the valve is got malfunctioned then it will not stop filling and this will cause the same problem. The valve in the freezer section.The ice-maker bin has to be removed to check the valve.Check the valve with meter and even the auger motor with meter. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
I need the part number to replace ice maker in GE Profile TFX27PF or TFT27PF
The replacement part number is WR30X10093 it is GE's newest electronic icemaker,all newer style icemakers and designed to also work for older models such as yours
GENE
Sep 17, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
KUIC15PLTS ice maker keeps making Ice even though it is FULL
The high level sensor can get iced up and stop working. using a hare dryer carefully heat the area that the lensing arm goes into or snap off the front cover of the ice maker and blow warm air in there. raise and loser the arm at the same time. a couple of minutes should do it.
Apr 19, 2011 | Kitchenaid KUIC15PLTS 15 Inch Wide 25lb...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 27, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
My ice maker stopped working
heatman101
gdshgsghshg
Jul 03, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
ICE MAKER NOT WORKING WHIRLPOOL ULTRA EASE II
heatman101
' 8798yuiy
Jun 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Motor screams like bearing is bad
If you dont have any luck getting them to replace the motor, send it to me... I can repair it. See here for information.
May 02, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Kenmore 19 Porcelain Plus (26 years old) with ice maker. The ice maker won't stop! The arm is raised to its highest point and I have tried lowering and re-raising it but the frozen cubes keep piling up. Is...
You may can take the plastic end cover off and find the mechanical switch which is supposed to be pushed when you raise the arm and cut it off. Being that old a slight adjustment (bending) may fix your problem.
Dec 18, 2009 | Refrigerators
Ice maker issue
Your icemaker could be over filling. Your fill tube into the mold could be misaligned. Check both of these issues.
Sep 28, 2007 | Refrigerators
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
