Question about Toshiba Computers & Internet
Hi all Technicians, I have Toshiba Equium A210-1as (PSAFJE). Problem: Shutting down itself after bios (post) - after 10-15 seconds or even 5 seconds depends how many times I want to turn the laptop on. I have tried with and without battery, RAM also I plugged another charger and is still doing the same thing... :( Please help
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked. You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 18, 2010
Toshiba equium m40x
this may caused by hard disk problem. first remove (disconnect) hard disk. then try to enter bios setup. if the problem persist, find a jumper clip named 'bios reset' in mother board near front panel connectors. the default jumper position is 1and 2. now change the clip into 2and3 - power on - wait 5 seconds - power off - reset jumper to 1and2- thats all connect hard disk- check again the bios setting.
Dec 12, 2013 | Computers & Internet
I can't enter in setup
Hi,How to enter setup page or the BIOS page
Brand : Toshiba - MOdel : Portege, Satellite, Tecra, EquiumPress F1 or Esc after powering on the computer to access BIOS.
Model: Toshiba Equium.Press F12 after powering on the computer to access BIOS
Apr 19, 2011 | Toshiba Satellite A45-S150 Notebook
My toshiba equium a200 starts up when u press up the power button but then automaticly turns off. do u have any idea what is wrong with it? i thought it was dead so i put in the charger also but it does...
HI Sarah,
It sounds like the laptop is overheating and shutting itself down to prevent damage to the components.
Try cleaning the air vents and CPU fan which are located at the sides, back and under the laptop. The best thing to use is a can of compressed air.
If that doesn't fix the problem then i recommend that you take the laptop to a reputable PC repair store and have a tech look at it for you as the problem could be the CPU fan itself is not working or even a more serious problem.
Regards.
Dec 10, 2010 | Computers & Internet
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
May 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
My toshiba equium laptop keeps randomly turning itself off - this could be after 5 mins or after 60 mins, but could be fine for a couple of days!!!
Hi:
your symptoms point towards a intermittent cooling problem...You might need to remove your cpu cooling fan, clean it up, and re install it, with new thermal paste. Make sure all fans in your computer are working as they should, including the power supply fan too.
Nov 20, 2009 | Toshiba Equium 100 PC Desktop
Toshiba equium 2000 bios power on password clear
1. Turn the PC off.
2. Unplug power.
3. Open case (Using phillips screwdriver)
4. Locate Bios Battery (Little silver disk)
5. Remove battery for 30 seconds.
6. Replace battery and case.
7. Boot into the Bios and see if it cleared the Password!
This only works for 90% of desktops.
As for laptops you usualy need to contact customer support.
Apr 21, 2009 | Computers & Internet
Laptop equium l10
Hi, My Name is Henry. I am one of the technicians here.
You need to upgrade your bios. Go to the http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click download and follow the instructions.
NOTE THAT YOU HAVE TO BE VERY CAREFUL WHEN UPDATING THE BIOS BECAUSE YOU COMPUTER MAY DEVELOP MORE PROBLEMS IF YOU DO IT WRONGLY.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 17, 2009 | Toshiba Equium 7100S PC Desktop
SYSTEM REBOOTS AFTER SHUTTING DOWN
It seems that when you formatted, you took your Bios settings with it. The latest bios can be obtained from toshibas website....Below is a direct link to the bios.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1976812xml&sliceId=&dialogID=51709196&stateId=0%200%2051707515
Sep 24, 2008 | Toshiba Satellite A215-S7422 Notebook
SOND FAILURE
open the sound device window in xp..by clicking on .... start/control panel/sound ,speech and audio devices/sounds and audio devices/......make sure firstly in the volume tab that vol is not set to mute or at a very low level ( i usually set it at max of 7) then click on advanced box and once again make sure none of the settings are set to mute. or very low ..you can fine tune these settings later if you wish...if you click on the advanced box within the far left master volume area then have the tick on in the s/pdif box....see hoe this goes and let me know
Jan 04, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
331 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
