Question about Sunbeam Heating & Cooling
Need a new fan blade - Sunbeam Heating & Cooling
  • 144 Answers
You can order online thru manufacture or johnstone supply sells to public
Posted on Sep 13, 2010
Need to replace fan blade. doi just the other blade off or do i need a tool
You should be able to get the fan off w/ a small screwdriver & some needle nose pliers for the metal clamp that holds the fan onto the shaft. Look on Google for suppliers to get a new fan & clamp. It shouldn't be expensive.
Apr 04, 2014 | Ecoquest Breeze AT Living Air Purifier
Need a new blade for blade bracket item #33221 Harbor Breeze 52"
Someone commented "Otherwise the fan blades are on upside down." The blades are reversible, with different finishes on each side, there is no way to install the blades "upside down". Not sure what they were trying to say...
I'm a retired electrical contractor that has installed, quite literally, thousands of fans.
Nov 15, 2012 | Dryers
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Aug 06, 2012 | Windchaser 3-way Oscillating Fan
I have an Aloha Industries ceiling fan and one of the blades broke on it! How can I get just one blade?
Unfortunately you can't buy one blade. Blades are made in sets and have to be balanced within a few grams of each other. If you can find the supplier for this brand there is a small chance you may be able to buy a new set of blades but you will need to know the model as well. Blades aren't interchangeable between brands or models.
Most likely you will need to buy a whole new fan.
Jul 29, 2010 | Aloha Housewares (93645) Ceiling Fan
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
Fan vibrates real bad. Needs a new blade. 18 inch floor fan. Blade is weak and bends easily.
Stick a small weight to the end of one of the fan blades with some sellotape , run the fan , if the noise gets worse transfer the weight to another blade.
When the fan is running quietly go to the blade opposite to the one with the weight on and drill out a 10mm hole in the material.
Take the weight off and check for balance if it is still out drill another smaller hole in the blade till you get a balance
Drill the holes a the tip of the blade so that you get the best effect from the removal of material
This will save you buying a new blade
Oct 09, 2009 | Outdoor Concepts 18-Inch High Velocity...
Blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
May 10, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Need fan blade.
I tried every link and selection on the WeatherWorks website in an attempt to find product information, but that was a waste of time. It's the least-friendly and least-useable website I've ever seen. For a replacement fan blade try contacting this aftermarket parts supply company (below). They seem to have every type of fan-blade imaginable: Electric Trading Co. PO Box 692, New York, NY 10013 Tel: (212) 226-0575 | Fax: (212) 941-1796 http://www.blowerwheel.com/ sales@blowerwheel.com (Although, to be honest, I think it wound be cheaper to buy a whole new window fan...)
Jul 31, 2007 | WeatherWorks DB888 Floor / Box Fan
Heating & Cooling Logo
35 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
