Zenith Z62DC1D Television Logo
Posted on Sep 13, 2010
FUSIBLE MODULO DE ALIMENTACION PARA LAMPARA - Zenith Z62DC1D Television
My benq515 projector indicates steady red on lamp
Hello Stand, that is indicating you have problems in the projector lamp, try to take out the lamp, clean the connection contacts and try again, if it works, well, otherwise you should do a replacement lamp
I sent you the link to download the user manual and follow the instructions to get the lamp
I hope you can find the solution to the problem
Greetings Franco Dosil
Hola Stand, eso te esta indicando que tienes problemas en la lampara del proyector, prueba sacar la lampara, limpiar los contactos de conexi?n y vuelve a probar, si funciona, bien, sino deber?as hacer un reemplazo de la lampara
Te env?o el link para que descargues el manual de usuario y sigas las indicaciones para poder sacar la lampara
Espero puedas encontrar la soluci?n al problema
Saludos Franco Dosil
http://www.lamparasparaproyectores.es/vp-manuels/videoprojector-userguide-benq-mp515.pdf
STR-K502P When I turn on I hear a click but no sound or lights Any ideas
Hello Billy, obviously your STR-K502P, has problems in the main power supply, control you have to remove the cover and look for a fuse indicated as; F901 FUSE (6.3Amp / 125V) and fix it is burned, if so, before replacing it, you would have to get a lamp holder and an incandescent lamp of 200 watts, the old lamps that bring filament, and connect the cables of the holder lamp to the ends of the fuse holder, the lamp replaces the fuse (serial lamp), you connect the STR-K502P to the power network and turn it on, if the lamp turns on completely and stays that way, it is very likely that there are components damaged and are generating a short circuit, in this case I suggest you look for a specialized technical service
If, on the other hand, the lamp is turned on and off or the intensity of the initial flash is reduced, this would give a guideline that there is possibly no short circuit, you can test the operation of the STR-K502P in this situation, if you can hear it, then replace it the fuse, its value is 6.3 Ampere / 125Volts
Once this is done, do not use the STR-K502P, without first checking all the cables and connections of the speakers, corroborating that you do not have any short circuit in them
I hope you can solve it
Hola Billy, evidentemente tu STR-K502P, tiene problemas en la fuente de alimentaci?n principal,controla tienes que sacar la tapa y buscar un fusible indicado como; F901 FUSE de (6.3Amp/125V) y f?jate se esta quemado, de ser as?, antes de reemplazarlo, tendr?as que conseguir un porta lamparas y una lampara incandescente de 200 watts, las viejas lamparas que traen filamento, y conectar los cables del porta lampara a los extremos del porta fusible, la lampara reemplaza al fusible (lampara serie), conectas el STR-K502P a la red de energ?a y lo enciendes, si la lampara se prende por completo y se queda as?, es muy probable que haya componentes da?ados y est?n generando un cortocircuito, en este caso te sugiero que busques un servicio t?cnico especializado
Si por el contrario, la lampara se prende y se apaga o baja la intensidad del encendido inicial, esto dar?a pauta que posiblemente no hay corto circuito, puedes probar en esta situaci?n el funcionamiento del STR-K502P, si logras que puedas escucharlo, entonces reemplaza el fusible, su valor es 6,3 Amper/ 125Volts
Hecho esto, no utilices el STR-K502P, sin antes controlar todos los cables y conexiones de los parlantes, corroborando que no tengas alg?n cortocircuito en ellos
Espero que lo puedas resolver
No reconoce sata RC410-M asterope2
Hay varias razones posibles de su SATA no funciona. Se puede desactivar en la BIOS. Si usted sabe como, entrar en la BIOS y ver si esta apagado. Si es asi, vuelva a encenderlo. El cable SATA podria estar danado o defectuoso. La unidad de disco SATA puede resultar danado o defectuoso.
El cable de alimentacion SATA podria ser defectuoso, o el dispositivo no este conectado a la fuente de alimentacion. La fuente de alimentacion puede ser defectuoso o seccion SATA de la fuente de alimentacion puede estar defectuosa.
Espero que esto sea algo util para usted. Tuve que usar un traductor para responder a su pregunta, asi que por favor me perdone si esto es dificil de comprender.
-Denny
2helpful
Where is the fuel pump relay located at?
behind left kick panel, asi dice en el manual, yo te podria decir que va detras del poste de la puerta delantero izq., el poste es donde van fijas las bisagras de la puerta, del lado del chofer, a la par del modulo ABS, por lo que se ve quitas una ventanilla de plastico (tapa) y detras de ella esta el modulo ABS y 2 relays, para que lo identifiques checa el color de los 4 cables q le llegan; Cable No. 1 *****/rojo, cable No. 2 *****/rosa, Cable No. 3 *****/amarillo, Cable No. 5 *****/blanco, en la cavidad 4 no lleva nada, suerte amiguito. pdta. este auto tambien lleva un modulo de control de bomba de gasolina tambien llamado FPCM que va ubicado en la parte trasera izquierda, (Left side of trunk) y tambien le llegan 4 cables.
1helpful
Mi alarma esta muy sensible, con cualquier ruido, como le hago para bajarle de intensidad?
Hola, debes buscar el sensor de impacto, normalmente lo instalan en el area inferior del volante o timon, es modulo que usualmente esta conectado al modulo de alarma por tres cables, tiene un indicador LED y un control de sensibilidad que se ajusta con un desarmador plano pequenio.
Fuente de alimentacion
Visita este enlace para encontrar la fuente de alimentacion para tu plasma.
6helpful
Nesecito saber como abrir la tv sony para cambiar
QUITALE DOS TORNILLOS GRANDES QUE TIENE ATRAS PEGADOS A LA ORILLA, UNO AL LADO DERECHO Y OTRO AL LADO IZQUIERDO, LUEGO ALAS HACIA EL FRENTE LA TAPA FRONTAL Y VERAS UN COMPARTIMIENTO DONDE VA LA LAMPARA, LE AFLOJAS ESOS DOS TORNILLOS Y LA SACAS.RECUERDA PONER LA TAPA DE ESE COMPARTIMIENTO LUEGO DE PONER LA NUEVA LAMPARA, SI NO NO FUNCIONARA.Y BUSCA EN EL MANUAL COMO RESETEAR EL TIEMPO DE LA LAMPARA.ESPERO ESTO TE AYUDE.
1helpful
Enciendo esta me funciona el fan de micro pero no levanta el video
Pueden ser una de dos cosas.
1. Fuente de poder esta defectuosa y no produce el suficiente amperaje para todos los componentes de tu micro.
2. Algun modulo de memoria esta fallando.
Comienza removiendo los modulos de memoria, y conecta solo una.
Enciende la micro a ver si enciende.
Si no, sacala, y coloca otro modulo, y enciendela.
Si no lo consigues, prueba con otra fuente de poder.
Una de las dos es tu respuesta.
No te olvides de dejar un comentario si te ayuda esta respuesta.
Pilla 6 veces y se estaciona en harward 3 y 4 y no envia señal a la pantalla
Los "pi" que escuchas en tu computador son codigos que la tarjeta madre envia para comunicar que hay algo que anda mal.
Dependiendo de la cantidad de "pis" y el intervalo entre ellos se puede descubrir cual es la pieza dañada.
Mencionas 6 "pi", y deben tener un intervalo quizas de 1 o dos segundos entre ellos.
Eso es definitivamente daño de memoria.
Para asegurarte cual es el modulo dañado, solo remueve toda la memoria que tienes instalada, y enciende tu computadora sin ellas..
Veras que los mismos "pi" siguen apareciendo.
Aprovecha y limpia los conectores de polvo etc.
Si tienes solo un modulo, entonces reemplazalo para que se solucione tu problema.
Si tienes mas de uno, instala uno a la vez para detectar cual es el bueno.
Asi tu computadora trabajara otra vez.
3helpful
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
