Question about E-Machines eMachines Desktop PC
It load up but shutdowm - E-Machines eMachines Desktop PC
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
It should be a vrius attack. Login into safe mode and troubleshoot.
Posted on Sep 14, 2010
COMPUTER SWITCHES IT'S SELF OFF AND WONT SWITCH BACK ON UNTILL YOU UN PLUG POWER SUPPLY AND RE PLUG POWER SUPPLY BACK IN?
Try new heat sync paste on top of the CPU and clean the areas of dust if any. Mine does the same thing I did this will all of my computers as well as all my clients computers as a preventive measure for overheating. Also it may be your power supply unit as well. So check out those two things and do necessary repair if needed that should solve the issue. It worked for me.
John
Apr 12, 2012 | Computers & Internet
My dell vostro 1015 laptop freezes intermittently. when this occurs, all buttons and the cursor will just freeze (fails to respond). i then had to force shutdowm by holding down the power button for 5secs....
When does your system freeze? Shortly after booting or my this be an overheating problem? When Laptops / PCs core temperature is too high they tend to stop responding. Maybe it could also be a driver related problem. Can you reproduce the error or is it happening only when you browse certain websites, etc?
Mar 02, 2011 | Computers & Internet
I have a 2000 oldsmobile alero and i drove it for like an hour and then when the temp. got to half it died and i let it sit over night and it will not start and the check engine light didnt come on until...
here are some causes for a bad coolant sensor-- rich running engine, increased vehicle emissions, engine shutdowm. if the sensor is bad, then when at normal tempurature the sensor is sending incorrect info to pcm. this sensor controls fuel and various functions. it is used to send correct info to pcm. so to compensate for engine management. have a good day !! have it scanned to find problem code. if check engine light is on.
Dec 29, 2010 | 2000 Oldsmobile Alero
I have a lg 42" lcd flat screen. My problem is a couple days ago i went to turn on the tv and only a blush black screen appeared, no audio or video
The power supply may have died or it is in shutdowm mode due to short circuits in the backlight inverter board. Please read my guide to understand how LCD flat panel TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 11, 2010 | LG 42LC2D 42 in. LCD HDTV
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Plugged up came on about 20 minutes later shut down and went to a yellow blinking mode monitor stays yellow i unplug monitor from cpu and works good do you have any suggestions
Could be getting too hot. Make sure all fans, cooling fins, heat sinks, HDD vents and weep holes are unobstructed and clean. Many computers have a BIOS screen at startup that will display system temp. Start it up and enter the BIOS, check CPU temp. Most PC's will shutdowm or reboot if temp exceeds 140 (this can be adjusted).
If not overheating, could be fault in a memory module, HDD failure, or CPU itself. But that's not that common in the scenario you're talkin about
Dec 11, 2009 | Dell OptiPlex GX260 PC Desktop
Pc shutdowm when I plug usb 2.0 device
Trying to chomp off more of your power.You can try one or all of these: If you have too many USB devices then try removing some or all of them.
You can try and delete all USB drivers under "device manager", run a restart so that windows can reinstall them. I would also suggest updating the motherboard bios and chipset drivers. I was able to cure the problem by disabling USB 2.0 support through the BIOS. On computer startup, it'll have "Press <DEL> to enter setup> or some other key. Once in, disable USB 2.0 support and that actually fixed the problem in my case as the user didn't mind the slower speed (just needed USB for printing).
Try turning off "allow USB to bring comp out of standby" It work for me. You can do this in Device manager/ USB Root Hub/Properties/Power management.
If none of these options work then it's either your motherboard or your USB drive.
Jul 18, 2009 | Compaq Evo D510 Minitower (Open Box)...
Shutdown problems
Windows does not shut down. Windows 95/98/ME may not Shut Down successfully or may lockup / freeze because ... may be difficult to trouble shoot or determine where the problem exists.
E-mail CHID: 5608 WHILE I SHUTDOWN THE COMPUTER IT WILL TAKE LONG TIME TO SHUTDOWM PROPERLY.
Read and follow instructions.Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
No picture. no sound
 have had this problem several times i think this is a manufactures default. i am in the proccess of contacting the manufacture email me we can talk aj@metrogeneral.com please let anyone else who is having this problem contact me as well.
Sep 13, 2007 | LG 52SX4D 52" HDTV
E-Machines eMachines Desktop PC Logo
13 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
