Question about Nova Development Photo Explosion Deluxe Version 3
I have version 3.0 and windows 7 and it wont load. i see the start screen with the lady on it but nothing ever happens. I really want to use this program like i do on my other pc.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button i have version 3.0 and - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Posted on Sep 18, 2010
Printer is on, green light, no apparent issue, go to print, item goes into que, printer does nothing
Depending on what operating system you are using, you may need the upgrade to the firmware or the software. if you have installed the drivers from Datacard, goto start, programs, Datacard printers, and you should have a monitor selection for this printer, launch it, and you will have to maximize the window from the icon on the bottom right of your screen, this monitor is the key to having the printer status and abilities to print with windows, without this monitor loaded (and it doesn't load properly in version 3 of the software with windows 7) nothing will happen, once it shows at the op "connected" then you can read firmware and software version at the bottom of the screen (I will need that information to help more precisely) also you should see a "test print card" on the left set of buttons of the menu, I suggest launching this if the printer is seen as connected. if it isn't you can try to use "resume".
Jul 29, 2014 | Datacard SP35 Plus Printer
My Sony VAIO Notebook VPCX11S1E wont boot up anymore. when i try it jyst goes to blue screen. How can i get iSony VAIO Notebook VPCX11S1E it to load up and start up normally.?
It seems that your machine is suffering a fatal error on startup. If the blue screen flashes up with some non-sensical writing on it then that is the error I speak of. This condition can be caused by a faulty piece of hardware, most commonly the hard disk drive in my experience. BUT it can also be just a faulty file in the Operating System on your machine and may not be a hardware problem at all.
Either way, the first ting I would do in your position is to reinstall your Operating System. You are using Windows 7 I see. Windows 7 is a good OS. In order to try to recover your computer you will need an original Windows 7 DVD disk. Insert the disk into the DVD drive and then follow the instructions at this like here...
http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/
Jul 08, 2014 | Sony VAIO Notebook
My computer wont load my pny memory stick
Is there more information you can provide? Examples, once I click the memory stick in, nothing happens on the screen with windows version? What size is the memory stick? Is it new from the store? What appears on the screen? If you open 'my computer' do you see it as a choice? If so, what happens when you click on it? Does it recognize it but not load the data off the stick?
Apr 12, 2014 | PNY Electronics - Others
I have a Compaq Presario CQ57 running Windows 7. When I use the webcam it loads and streams video fine, but only for the first 3-5 minutes. After that it zooms in to the upper right (as you look at the...
What program or browser are you using when this happens. Does this happen on a full screen? If so try using it in a window. Close all applications and programs before starting the cam.
Nov 02, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Windows 7 pc wont install windows updates after they have automatically downloaded
1. Did you try using Ms Fix it?
2. When did this issue start to happen?
3. The issue started happening on and what did you do: install something like software or a game.
Mar 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
I'm trying to load windows 7 on my hp pavillion dv6725 us laptop, it started installing then it failed i tried again it wont boot from cd but the rom is working th lights are blinking the tray is...
Do you have the correct version of Windows 7? You cannot load a 64 bit onto a 32 bit system, you cannot load Ultimate onto Home.
Do you still boot to the original op sys, what was it?
Sep 19, 2011 | HP Pavilion Dv6725us Notebook
I'm try to install new window 7 64 bit into compaq presario c700 ,but load and stand after window load. it says window starting and nothing happen.
Hi there !
If there is problem on loading you window 7. Try to run it on safe mode by pressing F8 when starting to reboot your computer. When running on safe mode, windows will automatically fix some error regarding some loading problems.
After press F8, just choose run on safe mode and it will read and fixed all errors on drivers. Computer can crashed because of faulty drivers installed or too many same drivers installed. This solution will fix your problem.
I hope it helps you. Thank you for using FixYa !
Jan 09, 2011 | Computers & Internet
My dell insprion 1520 wont go past boot screen it stars then goes to a black screen that says start up repair or start windows normally but when i click star up repair nothing happens then i pick start...
Place your windows cd/dvd in the tray and boot to the cd. When asked if you want to install windows, there will be a repair option further down towards teh bottom, or you will be asked to click R like before. The repair only works if the cd is in the tray.
Aug 26, 2010 | Gateway 7325GZ Notebook
Windows 7 does not detect CanoScan 3200F using its drivers.
Downloading Canoscan Toolbox is required in addition to the driver.
Oct 31, 2009 | Canon CanoScan 3200F Flatbed Scanner
Nova Development Photo Explosion Deluxe Version 3 Logo
254 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
