Question about Yahoo Messenger
I kept having the same problems with YM. Every time i tried to sign in, it won't let me sign in. it's about yahoo! messenger troubleshooter and It said " We can't let you sign in". I am sure it was not because of the internet connection. THANK YOU VERY MUCH
    President:
  • 2,291 Answers
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button. use registry cleaner reg in out to solve registry error for messenger
Posted on Sep 14, 2010
Im using yahoo messenger version 11 .i cant sign in anymore .. other website like facebook n search are okay except in yahoo ..what are solution of this problem..pls help
i got the same problem with my ym 11 too.. but honestly looks like its ym problem that it may just work whenever it want to.. :( but try this.. open Yahoo Messenger click on "Messenger" (on top), choose "Connection Preferences" select "Connect via Proxy Server" try to log in ..
if it doesn't work put it back to the original settings, same instruction go to YM, click Messenger then Connection Preferences select "Connect directly to the Internet".. this time try to disconnect your internet connection first.. and then with your YM open enter your username & password but dont click "connect" yet.. connect to internet & log in to ym (you should click "connect on ym right after a second you are connected to the internet)
Sep 10, 2011 | Yahoo Messenger
Hi, This is edith,my problem was about i cannot sign in to my yahoo messenger..I tried to download to all version..It is the same not working,,...What shall i do?
just try to wait maybe YM has an on going problem as Im having the same issue here right now I even tried to troubleshoot my connection..
Aug 05, 2011 | Yahoo Messenger
I coudnt sign in the yahoo messenger,while i can sign in yahoomail.what could be the possiblem problem?could you suggest solutions
Few sugesstions :
1) Uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
2) If it does not work, check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to: --> Control panel/ System & security/ Windows Update/ Change setting
In the setting panel, you will see " Important Updates " box selection. Change it to "Check for updates but let me choose whether to download & install them". Restart your pc/laptop, then try log in to your YM.
3) *This step won't be necessary but won't do any harm too, go to Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
** If it still crash, then your internet connection might be the problem, & also, Yahoo! can be down sometimes too.
May 27, 2011 | Yahoo Messenger
Im using globe broadband connection yet im unable to use ym
If you have Messenger 10 you will have the sign in troubleshooting facility to narrow down the possibilities.
If you have AVG free edition, there is a known conflict and you will have to contact AVG support for assistance ( Try signing in with AVG disabled to check this out )
Dec 05, 2009 | Yahoo Messenger
I am unable to sign in yahoo messenger. I am using yahoo messenger 9.0 version. After signing in it says problem signing messenger, try again.
1st sorry 4 my poor English.
if you have problem to sigin Yahoo Messenger(YM) . 1st you check the internet explore(IE)is working correctly. most of the time it don't work. (but Firefox,chrome,Gtalk,etc..etc.. are works correctly)
so go to IE ->Tools->Internet options->Connections->LAN Settings-> Check Automatically Detect settings and uncheck other options (See the Screen shot below).
Now IE and YM will work fine....
Sep 16, 2009 | Yahoo Messenger
Yahoo Messenger Problems Today
Are you using Vista OS? I believe that YM 9 for Vista is still under beta testing. There are bugs that needs to be fixed for this YM to work efficiently. Until all these minor problems are addressed by Yahoo, you will have to bear with this problem. I suggest you use the older version, that works better than the new one.
Oct 22, 2008 | Yahoo Messenger
I cann't sign in yahoo messenger
Please check that your firewall is blocking the messenger. If you donot have fire wall installed then its a virus or Spy ware is blocking else the messenger is corrupted. First check firewall settings.
Regards
Rafique
Feb 18, 2008 | Computers & Internet
Connection/sign in problem
did you try to reinstall it again.. ym always has a problem.
Jan 22, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
130 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
