Question about Yamaha RX-596 Receiver
Yamaha rxv596 receiver shuts down after relay clicks on
  • 7 Answers
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Posted on Jun 05, 2007
techman
  • 3130 Answers
SOURCE: Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Posted on Jun 06, 2007
dsom
  • 56 Answers
SOURCE: Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Posted on Jun 07, 2007
satavlad
  • 405 Answers
SOURCE: yamaha receiver will not turn on. just a clicking
Your unit have had detected a fault and enter the protect mode. To determined, what exactly wrong with it, you will have to take it to Yamaha authorized repair facility.
Posted on Dec 26, 2009
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
Apr 13, 2010 | Yamaha HTR-6030 Receiver
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Feb 29, 2008 | Yamaha RX-V730 Receiver
Will not turn on.
It has an internal problem. Just received an RX-V2600 back from service for the same issue. It took a voltage drop then a spike. It takes out 5 caps and a few other parts. The repair will run roughly 250-275 depending on who does the service. Hope this helps
Aug 14, 2009 | Yamaha R-V905 Receiver
Yamaha rx-v663 receiver worked only one week. next time i went to play stereo as soon as i turned it on it only stayed on about 2 seconds then shut down. i am able to try three times with same results...
The click is the autoprotection relay that should be allowing the amp to stay up. Try this... turn the speakers off if you can, or disconnect them then try again. Safety shutdowns are usually either heat or short circuits in the output stages. It doesn't stay up long enough to get hot so...
If it stays up withou the speakers on then the problems is probably external and easy to isolate.
Let me know.
Apr 03, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Immediate shut
Jun 06, 2007 | Yamaha RX-V630 Receiver
Jun 05, 2007 | Yamaha RX-V630 Receiver
Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Mar 27, 2007 | Yamaha HTR-5890 Receiver
Yamaha RX-596 Receiver Logo
207 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
