Question about Whirlpool Washing Machines
Hi: I have a Whirpool washing machine and it is leaking at the right front bottom area. I do not know how to open the machine up and look at the problem. If you could help me, I would really appreciate it. Thank you. Sue
  • 121 Answers
Maytag 2011 maxima water not draining fully from front seal. And water is leaking down the right side. What can be wrong?
The bellows is clogged that can e cleared by opening the door and checking the area just outside the tub at the bottom for debris. Clean this area and should drain normally into outer tub.
Oct 20, 2013 | Maytag MHW6000XW - MaximaTM...
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer - error code f35. shuts off
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a ge front loader washing machine. Only had it a year. It is sitting on the drawer station. My washing machine is leaking all around the bottom. I have no idea how long it has been leaking,. What is...
Plug off the wall mains. Open up the machine to first check the water hose coming to the machine, then the large hose going to the drum, then the exit hose bottom of the drum, then the pump & filter area. Surely you can locate where the leak is. Could be one of the hose has become loose. If torn or worn out you can replace, it is easy.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl rate me nice for the free help, thnks.
Apr 21, 2010 | GE WSXH208A Front Load Washer
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
Washer leaking from door area
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE washer is leaking! Hellllp!
hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
