Question about De Dietrich 18 in. VZ9456 Built-In Dishwasher
Dishwasher goes through part cycle with cold water, doesnt release the tablet then stops and the "Rinse and Hold" light and the "Intensive 70C" light flash and the washer bleeps then stops.
  • Andy Chisholm Sep 14, 2010
    Hi cmmisuer01. The instructions I have are in english and dont mention delayed rinse cycle. How do I cancel this cycle. I have tried the power off power on solution to no avail. There is no water sitting in the base. The dishwasher drains fully. The dishwasher was purchased in the UK.
  • Andy Chisholm Sep 15, 2010
    Thnxs Ginko. I took your advice and left a message with De Dietrich but I believe you may be right about thermostat. If I get the solution from De Dietrich I will be back to accept your solution.
  • De Dietrich Master
  • 19,396 Answers
Hi.
Check if the dishwasher is heating, if dishwasher does not heat, then either thermostat or element is faulty. Both get tested rteading Ohms at their terminals, if either one is open it must be replaced.
If the detergent compartment door does not open, that must also be tested, I think that the slot does not open because temperature is not reached.
There is no much literature on De Dietrich dishwasher. The first thing to do is surely contacting De Dietrich at the number listed here (UK), if you are not located in UK, please use the contact form: Contact De Dietrich.
If you repute this solution helpful, please do not forget to accept.
Best regards.
Ginko.
Posted on Sep 15, 2010
  • Ginko
    Ginko Sep 15, 2010
    OK.
    Please keep me updated on your problem.
    Regards.
    G.
  • 3,247 Answers
I am assuming the instructions you have for this model are not in English.
It is likely the dishwasher is in Delay rinse cycle.
Have you tried to turn the power off and back on.
Do you see the water sitting at the base when you open the door?
In which country did you purchase the dishwasher?
Please post a comment so that I can get some better diagnostic for you.
Posted on Sep 14, 2010
  • 1 more comment
  • Sam Sep 14, 2010
    Thanks for clarifying the information I had sought.
    This enabled me to actually locate the correct user manual for your dishwasher.
    Obviously the problem you are experiencing is not covered in the trouble shooting guide. The closest is "Rinse and Hold" and "Normal 60" lights flashing which means inlet water problem.
    But this is not the case as you mention the dishwasher goes through a part cold water cycle. But what intrigues me is that there is no water at the base of the dishwasher when you open the door.
    Especially if the detergent dispenser is not opened - there was no wash cycle started. So the important thing is how did you work out that it goes through a partial cold cycle.
    Please confirm which cycle do you operate the dishwasher in - does it always behave the same. What happens if you try the "rinse and hold" cycle?
    ALos please check if the water inlet tap is not shut by some co-incidence.
    I hope we can help you get this problem fixed soon.
    i did as you suggested and tried another cycle. i tried the "Bio 50C" cycle. it stopped again with the same lights flashing but i notice this time that the base of the dishwasher still had water sitting on it. i switched the washer off and on and it is now running the "Rinse and Hold" cycle to empty the water. the water is still cold and not heating up but this time the detergent has been dispensed.
  • Sam Sep 14, 2010
    I am assuming you are trying other experts to assist with this problem as you have already declined my solution. If you are still interested in my help then please clarify which wash program were you running previously when the problem was noticed. I had asked for this information in my previous post..
    You mentioned the Bio 50 program gave a different behaviour but did not say what program you were using before. You have to be patient sometimes as the consultant does not see what you see. Has to depend on the words in which the customer desribes the problem.
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
Why dishwasher started making growling sound all of a sudden?
Possibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Remove any debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.Loaddishes and re-check
Apr 09, 2012 | Maytag Dishwashers
E 15 problem code on Neff dishwasher
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.Turn the main water supply and main power offE15 error means the anti-flood system as activated; you havehad an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door youshould be able to access the base to remove any excess water.Behind your kick board is a plate below the door. Remove theplate.
With the power off push a rag into the base plate to soak up the water.
Failing that pull out the dishwasher onto the floor and tilt the machine backto allow the water to run outSwitch the water and power back on and restart the programto test.If the appliance is less than 2 years old Neff/Bosch Groupguarantees it
Apr 07, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher stays in cleaning mode and does not cycle to rinse.
Hello their sounds as though water heater has failed if it doesnt heat it defaults to a 3 hour cold wash and never finishes cycle eg doesnt go through rinse stages.will need a new heater service tech to change as fairly complicated.
Nov 02, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My dishwasher is brand new and is not drying the dishes!!! they are still wet. the model number is she55mi 2uc/60
If you are using a quick cycle there is not a dry cycle included due to the short wash. Ensure you use rinse aid even if you are using a product that includes it, as this assists the drying cycle by breaking the surface tension of the water and allowing less water to 'stick' to the load. Check that you have the machine set to the use the rinse aid and that the intensive dry is on. This can be done by following the instructions in your manual.
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying time for improved drying.
This option is only for units with a display. If your unit has a display window, please follow the instructions below.
NOTE: The unit must be powered OFF before activating.
To activate:
Press and hold the left "Cancel Reset" button, then • press and hold the ON/OFF button.
The model number I think should read SHE55M12UC/60.
I hope this helps.
When the LED display window indicates a "0" or "1" • release both buttons.
To activate extra dry heat, press the left "Cancel Reset" • button until the display indicates "1".
To disable extra dry heat, press the left "Cancel Reset" • button until the display indicates "0".
Press the ON/OFF button to save the setting.
Jul 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher model: SGS56E02 will not complete a cycle.
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more...
Sep 27, 2009 | Bosch Dishwashers
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
De Dietrich 18 in. VZ9456 Built-In Dishwasher Logo
202 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
