Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do I change the print head on my Brother MFC 240C...the magenta is not printing right. When I clean the print head several times, run a test print the magenta only prints about 50-60%. When i print in moderate fast speed some of the magenta prints, however if I print in normal or fine mode it doesn't print at all.
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-240C Change Unable 50
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Dec 12, 2007
  • 134 Answers
SOURCE: Brother MFC-240C Error 30/50
The problem with this machine is that you need to take off the top tilting cover, then remove several screws to take off the lower top cover. The print head is then visible. If you don't have experience, I wouldn't recommend it. You can ship it to me if you like. We are a Brother service center for 18 years. I'm in CT.
Posted on Sep 02, 2008
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
  • 10 Answers
SOURCE: Error 50 after jammed paper on brother MFC-240c
I had this too, I had to open the back of the machine, it is meant to open and pull out and clear the jam (pull out the crinkled paper) but everytime I tried to print again it kept saying that it still had the jam, I opened and closed it several times and it did not seem to register that I HAD CLEARED THE JAM, so what I did was unplug it from the wall and then plug it back in and then it was fine. I wonder if this is AN ACTUAL DEFECT with this machine, if ater a paper jam it cannot detect that it has been resolved without having to unplug it and plug it back in, HOPE THIS WORKS FOR YOU.
Posted on Jun 19, 2009
How to change printer head on brother printer mfc-495cw
Do not try it on yor own unless you are a technician. Too many parts must be removed and counters have to be cleared and programmed. You might try calling brother, they will cover printhead replacement on certain models. Call 1-877-brother.
Feb 17, 2015 | Brother MFC-495cw Color Inkjet All-in-One...
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
Hi my printer is a mfc 240c and i changed all the ink cartidges but everytime i try to print or copy anything it stays printing blank pages so what can i do to fix it
You'll have to run the cleaning mode a few times,
to do so you'll have to get into Maintenance Mode.
To do this:
Press MENU then * then 2 then 8 then 6 then 4
This takes some practice and you have to press them all within a few seconds.
If the machine doesn't say MAINTENANCE when you do it press STOP/EXIT and try again.
When in Maintenance Mode:
Press 7 then 6, then press 3, then press BLACK START
It will say Cleaning - this will take some time when it's done it will go back to MAINTENANCE
After it's completed try 0 then 9, this will print out a small Print Quality test page
it should have several rows of each color (Cyan, Magenta, Yellow and Black)
if they still don't look right then run the cleaning mode again and then print another quality page.
Continue to do this until the quality is back to normal,
when you're done to exit maintenance mode press 9 then 9 to return to normal operation.
note: this cleaning mode uses up a fair amount of ink, use sparingly
note: maintenance mode is for brother technicians and has some codes that can damage your machine, only use the codes I've explained in this solution
If this doesn't resolve your issue you may need a replacement print head,
this is an expensive fix if the machine is no longer under warranty.
If it is under warranty contact Brother and they will arrange a meeting with a local technician to repair it for you.
Jun 02, 2011 | Brother MFC 240C All-In-One InkJet Printer
OUR BOTHER MFC-240C, DOES NOT PRINT THE BLACK CARTRIDGE. IT IS A FULL CARTRIDGE, AND GOES THROUGH THE MOTIONS AS IF IT IS PRINTING, BUT COMES OUT BLANK. I HAVE HAD THE MACHINE RUN THE CLEAN FUNCTION...
i have the exact same problem! i have a brand new cartridge i took of the yellow thing it says to remove, and i put it in properly. it recognizes it, it has cleaned it several times. i have restarted my computer and the printer, i have unplugged and replugged. when i did the test print only the yellow cyan and magenta showed up. i am very frustrated! any help would be appreciated.
Dec 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother MFC 5890CN printer and the yellow and magenta only prints a couple of squares on test after several cleans
It may be worth changing them again, you can on the odd occasion get a couple of duffers.
i would start afresh & do a head clean then a print test with a brand new set in.
If you get a perfect set of squares as the screen shows then its done if not repeat the head cleaning process untill you do, once you got those squares right your done.
Nov 09, 2009 | Brother MFC-5890cn Color Flatbed...
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Magenta Color Doesn't Print
refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Feb 02, 2008 | Brother Multi-Function Center MFC-240C...
MFC-240C colr problem
No. Just buy original carts and install them. Run the manual cleaning procedure twice. Wait overnight and repeat the manual cleaning again. Should work. (..and give the compatible ones a dump)
Jan 16, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
359 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
