Question about John Deere Garden
How to replace mower belt on L120 - John Deere Garden
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
richroth
  • 9472 Answers
SOURCE: I have a JD L120
Here is the complete belt replacement guide for your mower. Go thru all the steps to make sure you are installing it correctly.
Posted on Aug 30, 2011
L120 48 inch cut belt diagram
Google it make and belt routing diagram
Aug 08, 2016 | Garden
L120 cuts great but wont pull up a hill
replace the drive belt .they do wear out
May 07, 2016 | John Deere L100 Series
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
Drive belt # for l120
John Deere L120 Drive Belt
GX20006 OEM Number
Stens 265-186 1/2" x 88-1/2"
Rotary 10434 17/32" x 88-5/8"
Oregon 75-979 1/2" x 88-5/8"
Aug 14, 2014 | Garden
John Deere L120 Lawn tractor, Mower will not engage.
could be the switch that engages it also check to make sure that the blade is not stuck by something do this with mower shut off
Oct 20, 2012 | Garden
Problem with John Deere L120 tractor
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I am trying to replace the belt on a John Deere L120 lawn tractori need a diagram on the right setup
CLICK HERE for step by step instructions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for naswering your FREE question.
Jun 30, 2010 | Garden
I have a L120 riding lawn mower and the blades won't engage, it was just working last week and for some reason quit this week, the motor and everything else sounds good, any solution?
Check your deck belts to be sure they haven't jumped out of place (off the pulley someplace or the belt guard has bent allowing it to run sloppy).
This usually occurs in tall grass. Depending on how old the belts are they may need replaced.
Jun 21, 2009 | Garden
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
Garden Logo
115 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
