Question about Coleman Electrical Supplies
I have a Powermate "Professional Series" w Yamaha MZ360 . It always starts first pull...but..it began dying after a minute or two and would just have to restart to get going. Now, the longer we leave it off, the longer it runs BUT it will shut down within two minutes after startin It even seems to have two places to add oil. Does anyone have a solution?
Take off the carb and flush it with cleaner. You should see gunk come out. Dry it and reesemble it then give it a shot.
Posted on Jan 20, 2011
Nead specs for yamaha mz360 intake valve
You need to yamaha this type of inlet valve? Our company is to do motorcycle accessories in this area, if it's convenient, would you can go to our website to see http://www.motorpartstore.com
Apr 07, 2016 | Yamaha Motorcycles
MZ360. What is compression in psi?
I have same generator. Will not start. Good spark, good fuel, good carb. Compression is 60 psi cold. Is this good? Bad? I can't find anything on what compression should be.
Oct 01, 2015 | Yamaha Electrical Supplies
Yamaha mz360
check for spark, if no spark check oil level as low oil level cuts the spark
Nov 03, 2013 | Electrical Supplies
WHERE CAN I GET YAMAHA MZ360 IN SOUTHAFRICA,JOHANNESBURG .I AM IN ZIMBABWE,BULAWAYO
Unit A4 The Palisades Business Park 39 Kelly Road Jet Park East Rand, Joburg (Come visit us Mon-Fri: 7:40-16:00);
Dean Webster Charles Stuart Cell 0837015332 Cell 0833071580 Fax 0118809089 Fax 0118809089
Jan 27, 2010 | Coleman Powermate Premium Plus 6250W...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 6750 powermate with yamaha mz360 electro ignition cranks and runs fine but doesn't put out any power brushless how do i get it to produce power again?
One of two things:
1. The rotor has lost all the magnetism it needs to get started generating. It needs to have a tiny bit to get started.
I have used the system of a couple series 150 watt lamps between the generator and the utility power. Search Google for description of this method. I have used it and it works.
2. You have blown diode(s) on the rotor. They would have to be replaced. I have not found a source and had to make my own.
Oct 24, 2009 | Coleman Electrical Supplies
COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Feb 27, 2009 | Coleman Powermate Subaru 5000W Portable...
I have a coleman powermate 5000 genertor w/a subaru engine.
Try removing the float bowl from the carbuerator and empty it out. Also check the float valve to see if there is debris under it. Thi problem is definitely fuel.
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
257 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
