Question about Vacuums
We have a Garmin Gps 12 XL FCC id iph-17800 s/n 35538540 and the person that know how to operate it left our co.
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Motor is random like a short
It sounds like you probably have a bad spot in the cord. What happens is you get a kink in a spot or you run over the cord and it loses continuity there, but only when it's bent a certain way. Turn it on and wiggle the cord from one end to the other I think you'll find the problem there.
Otherwise, if that isn't it, your motor is possibly the problem. Does it smell like burnt electrical when its running? A frozen motor carbon brush will cause this or just plain worn out carbons can do it as well.
Lastly It could be the switch but they generally just stop working and its on or off and no in between.
I'd bet it's the cord.
Happy Vacuuming!
The Vac Dr
http://vacuummedic.com/product.php?id=181
Jan 13, 2013 | Oreck XL Ultra Bagged Upright Vacuum
I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I have a new steam vac power max without instructions I need to know how to operate it
Hiyas ive found you an online downloadable manual go to this site and after its loaded look where it says product manual and click on that then click on the product manual again and it should open a new window showing the manual, when this window is fully loaded click on the disk top left to save a copy to your computer for printing
http://home-solutions.hsn.com/hoover-12-amp-steamvac-powermax-carpet-cleaner_p-2750224_xp.aspx
Jul 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Dont forget to rate appropriately, thanks.
Mar 27, 2009 | VAX Appliances Vax X5 Bagless Upright...
Oreck XL Vacuum
If you can find a Kirby G series vacuum lightbulb, it will work in the Oreck too!! Many sellers carry them online.
Apr 21, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
