Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
Moyer Diebel 501HT goes to temp 57 degree C, it should go atleast 71 degree C, What should i do ? thx.
    Problem Solver:
  • 40 Answers
First item to check would be the high limit switch attached to the outside of the booster. Should have 2 wires. Switch is the size of a dime. The switch has a reset button at the centre. Just push in slowly. You should hear or feel the slight click. Do not touch the wire or terminal at the switch when power to machine is on.
Posted on Feb 13, 2014
2 Suggested Answers
  • 86 Answers
SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Posted on Jul 02, 2009
No heat in 501 LT
There's only 2 wires doesn't matter which goes where. Check the hi-limit (small round disk) push the button with power off. You'll feel Click if it needed resetting
Aug 22, 2012 | Moyer Diebel 24 in. 501HT Built-in...
I can not get the water temp to above 180F and the local health inspector realy want it to have the minimum of 71 degree celcius or 180F.If I leave the machine idle the temperature gauge show 72C but as...
Hello Huekycanada
You have to check the booster element what amp they are drawing there are three elements if only two are working it will still goes up to 72C may be it need longer time to get there. Secondly I would check the in coming water from your hot water tank it should be 60C at the machine , To check this incoming water temperature the best way is checking the temp. at the sink nearest to the dishwasher. 9 out of 10 I do find this is the main cause of the problem ( the in coming water temp is too low)
All the best, Dickson
Apr 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Model# 501 ht mb HHH message in both wash and rinse temp display at different intervals,extreamly hot. cant find manual, washer installed 2 yrs ago not 1 problem untill yoday
Possibly the booster thermostat needs replacing. Expansion of the water in booster enters the wash tank when boiling showing HHH on both displays.
Mar 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
My 501-ht doesn't dispense detergent?
Could be clogged hose or filter screen. Could be pump hose worn out. Check that the hose goes to the bottom of the detergent container. Could be detergent pump not operating. Could be timer switch not working or not adjusted properly.
Nov 30, 2010 | Moyer Diebel 24 in. 501HT Built-in...
When we close the door and put switches on, only the temp light comes on. nothing else happen. Thanks
Could be the switch marked delime is in the on position.. That switch should be in off position. (pushed in at bottom)
Sep 11, 2010 | Moyer Diebel 24 in. 501HT Built-in...
I have an older model 501ht. It is not getting to 82 degrees centigrade only about 75. Needs to get to 82 to sanitize properly.is there an adjustment I can tweak ?? thanks
Could be that the temperature guage is innaccurate or adjust booster thermostat higher with a screwdriver at centre shaft on thermostat. If you have 2 thermostats together, then its the thermostat on the right side looking to the front of the machine. If the thermostat is already at maximum then replace.
May 21, 2010 | Moyer Diebel 24 in. 501HT Built-in...
Moyer diebel 500ht manual
Hello there
Are you ok now , or still looking for the manual if you are then send me a message to my email address and I'll tell you how to get an manual for you machine. if not I'll send you one , God Bless have a nice day Dickson
Jul 16, 2008 | Moyer Diebel 24 in. 501HT Built-in...
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
118 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
