Question about Ace Hardware Ace 2Gal Home and Garden Poly Sprayer
HOW DO YOU PRESSURIZE ACE 22420 SPRAYER? - Ace Hardware Ace 2Gal Home and Garden Poly Sprayer
Model 030XPEG. Why won't sprayer pressurize?
Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden
www.amazon.com > ... > Sprayers
Amazon.com, Inc.Amazon.com : Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden ... Kit with Extension Wand and Adjustable Nozzle(Only for models 1991A, 1992A, .
Oct 08, 2015 | Gilmour Garden
Will not pressurize
Seals not sealing check cover rubber gasket and relief valve
Mar 05, 2014 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
Just bought the Ace 2 gal poly deck sprayer but it will not spray just puts out a stream of stain..is there something extra I should have purchased to get this to spray ??
I had the same problem. The deck sprayers are meant for thin liquids, not the heavy stains. Some stains have a thin consistency, others are thick. You can go back and buy a thinner agent for your particular stain, but , in my experience doing that, it thinned it too much, the color was off and didnt cover right. I ended up using a roller and brush to do the job right.
Sep 19, 2011 | Ace Hardware Ace 2Gal Home and Garden Poly...
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
How do yo get the sprayer to actually spray there is no pump to build the pressure to let the spray out. Is there instructions to the sprayer I have missed placed mine if there was some in the box
Here is the web site link for your sprayers manufacture. on the bottom rt is the model you can choose yours and get the manual you need. as you know there is usually some way to pressurize the tank, either hand pump or air pump. This should help and if you need more help please contact me. Thank you http://www.gilmour.com/tips-tricks/
Jul 13, 2011 | Gilmour Garden
I cannot pressurize the sprayer. I have the solution in the sprayer. Handle is screwed on. No spray comes out
When you pump the handle is there resistance? If there is, pressure is building up in the sprayer.
If there is no resistance, the sprayer pump is probably deteriorated and should be replaced.
If there is pressure and when you squeeze the trigger nothing comes out, remove the nozzle and make sure there is nothing plugging it.
Good Luck,
Gary
Jan 09, 2011 | Garden
Tank will not pressurize after pushing the pump handle down multiple times.
the reason it might not pressurize is there might be a hole in your tank or hose to the spraier itself if it has holes in the hose get a new one put it on the tank and handle. if hole in the tank duct tape it or seal it with a sealent. but it wont pressurize with a hole because the air comes in and out of the hole. hope this helps you
Jul 02, 2010 | Gilmour & Spray Doc& Poly Tank Sprayer...
Ace Hardware Ace 2Gal Home and Garden Poly Sprayer Logo
89 people viewed this question
Top Ace Hardware Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ace Hardware Garden Expert? Answer questions, earn points and help others
