Question about HP Computers & Internet
My Hp p6140f desktop computer will not start-up. on the diagnostic tools I hit on start -up which is F9, it said the hard drive had a BIOHD-8 ERROR AND ON Boot path was BIOHD-4 error any ideas? nothing was done to the BIO system or anything like that, the desk top came on and the mouse battery needed changed, the screen was all blue when I got back to the computer . I shut it off and turned it back on and the diagnostic tool program came up. I tryed all of them out and still no luck, thanks
  • HP Master
  • 1,906 Answers
Show photos of your screens?, it's a no boot symptom.
Photos of your bad screens is like magic.
2010 desktop, (oldest it can be) the COIN cell can be bad now. (Bios acts funny with this bad)
Battery is at the upper end of its life span now. at 7 years.
if true BIOS will not operate correctly
are you saying the ESC key fails, and F11 key fails>?
Esc is BIOS page, and F11 is reload or refresh OS
what OS are you running , Vista or W7? or what?
oldest this pc was VISTA.
That error code means.
Data from the HDD is dead,or corrupted, why is the question.
Or a corrupted OS or bad PSU.
there are simple tests to find true cause.
Boot and press ESC and do the diagnostic page, yet.
the press disk tests?
can you build a live linux or live windows PC disk and boot that?
or on a usb stick boot that, and prove the system is ok and only the HDD is bad? that is what shops do...'
clean out the dust in the system and CPU fan heat sink so it stops the overheating there.? 7years of lent is a horror, did you look?
Many be that lent cause HDD overheating and is why IT FAILed,
as it boots hit f11, and do the restores seen there.
the HP REstore modes. get errors NOW?
that BIOHD8.
I sure could be a HDD, but we do tests to prove its is first.
If F11 restore fails, you run it and it gets HDD errors, then there are errors coming down its data cable, for sure. but way.?
1: its bad. the HDD.
2: the PSU is bad, cause it to malf. bad (low 5v , low 12v, or noise)
3: the cable to it is loose or fell off. or bad. SATA cable.
4: the HDD is overheating, are all the PC fans dead.?
5: I boot to a CD and run SMART, from Crystaldisk.
http://crystalmark.info/software/CrystalDiskInfo/index-e.html
6: even the Sata port on the mother board can be bad, try port 2? TO PROVE THAT,, you have to change bios to boot to port 2, so...
you have 2 choices, guess, or test, I'll not guess, and then let you call me a liar later, as seen here at the real HP forum.
if you do the test, you learn what's. bad.
1: booting from Live CD or stick linux or windows. PE.
if this works great the base machine is ok.
2: move (suspect )disk to other PC and doing smart test on it and other HDD tests, we have who bucket of test apps to test HDD in shop.
the BIOS has a disk test, but is simple and does find weak HDD. (there are vastly better HDD test tools)
3: The SMART test tells you if it's , ok, not overheated or if its OUT OF SPARE TRACKS (redundancy repair system is toast) or even DEAD.
4: F11 key fails, tell me HDD is bad, Power to it bad or SATA port bad. F11 restore.... do the startup ,fix first. this is simple does that fail>??????
5: if the HDD passes all tests in another system its ok. (if you run the best HDD tests there its ok)
6: if the boot to linux, or windows live PE fails even with HDD removed. and it fails, its not the HDD is it.
that would be... (it's a system )
(fans, mobo, PSU , CPU , etc) the CPU can pack in lent and overheat in seconds, saw one guy here put a new fan on it and wrecked the heat sink compound and now overheats in seconds. (he went from bad to worse)
we do tests. and find the truth, if testing is old hat, and boring???
then throw parts, but if you have data there,
we try to recover data first. do you?
try a new HDD.
but wait, OS needs Install DVD or Usb stick install.
Got the HP install media kit, if F11 fails, then the restore part is lost.\
so only media kit can work. if at all.
have you at least tried reading on at HP
you know, HP.com
the page called my PC dont start?
why not?
first a good page on this error
http://www.solvusoft.com/en/errors/runtime-errors/microsoft-corporation/windows-7/biohd-8-windows-7-error-code-biohd-8/
If you research this this error is pure Microsoft
its not HP, at all, its MS, built in SMART monitors.
it can be turned off in BIOS, on some PC.
now HP. seem like good advice here, as usually buy the top guys.
https://h30434.www3.hp.com/t5/Desktop-Operating-Systems-and-Recovery/Error-Code-BIOHD-8/m-p/990779/highlight/true#M39824
try to learn 1 thing in electronics.
try to know that all HDD fail. or seem to...
if :
power to it is bad. or noisy ,yes, PSU can fail 3 ways.
dead, low-voltage or NOISE.
the data line is bad,or SATA port to it bad.
or the HDD overheats.
or has been dropped or is clicking,
if data is corrupted, that can be virus infections.
and nothing at all to do with HDD, period.
but COde 8 , I think, is MS code 8 means, SMART FAILS.
it means MS sees data on the SMART pages that is wrong. so run smart and find what is there that is wrong.
I just replaced 1GB drive due to smart showing me
it just ran out of spare cylinders, (they all do that in time, took 7 years) but did, and now is paper weight. I always check smart, like once a month on my DATA DRIVES. and I'm always backed up.
Posted on May 27, 2017
  • Anonymous May 27, 2017
    https://support.hp.com/us-en/document/bp...
    there is no lack of help at HP.com
    why hide from them>?
    Top Expert:
  • HP Master
  • 77,514 Answers
Sounds like the hard drive has failed.
Posted on May 26, 2017
vincent721
  • 240 Answers
SOURCE: windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
Posted on Mar 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: BIOHD-5
hello there
depending on the error code it is hard to determine what the problem is
but here is a link that should cover almost all of the codes
  1. C H a P T E R 1 - Troubleshooting Tools POST diagnostic and error message reports are displayed on a console. ... 0) Tests Failed:0 Elapsed Time: 0:0:0:25 If you specify a path argument to test ...www.scribd.com/doc/16604965/C-H-a-P-T-E-R-1-Troubleshooting-Tools - 94k - Cached
Posted on Sep 14, 2009
Cycoman
  • 81 Answers
SOURCE: I have an HP Pavilion a6452f PC with error code BIOHD-8
ok best thing to do is take it to a office store there they will copy all your files to another hard drive id do this before you tryed any else
Posted on Mar 24, 2010
TheChiefGeek
  • 7 Answers
SOURCE: I have a Seagate Barracuda 7200.11 hard drive that
Hi Levi08. By now you probably already have 1) resolved or 2) tossed the offending Seagate, but maybe this will help others out there with 500GB - 1.5TB Barracuda 7200.11 drives that may be experiencing this problem now.
Check out this Seagate forum: http://stx.lithium.com/t5/ATA-and-Serial-ATA-drives/Barracuda-7002-11-not-detected-in-Bios-or-Windows/m-p/45355
CNET discusses the firmware issue in more detail here: http://news.cnet.com/seagate-fixes-7200.11-drives-except-when-it-doesnt/
In a nutshell, most failures where the 7200.11 can't even be read by the BIOS suddenly is a flaw in the original firmware. Because of the range of HDDs this affects, Seagate has allows end-users to have access to the firmware and it is reported that Seagate will perform data recover of any drives that crashed with the faulty firmware.
The Chief Geek
www.TheChiefGeek.Org
Posted on Apr 28, 2010
techman
  • 3130 Answers
SOURCE: ACER desk top computer does
There could be tons of reason for a computer not starting up! the first thing I would replace would be the power supply, then the memory sticks or even the entire motherboard could cause it. does the computer beep any tones when you first hit the power supply, no? replace the power supply unitassy.techman
Posted on May 08, 2010
How to manage BIOHD-8 Error Code
Hi
If your drive is showing a SMART error I would consider replacing the drive as its showing the 1st signs of failing and if you don't have backups of any important data on there I would back it up now as when it failes you wont have any way of recovering your data
Cliff
Aug 21, 2014 | HP Computers & Internet
The product is compaqe presario CQ32701X desktop PC and the problem is..... window is not starting normally. when we did pc diagnosis (F9). while testing ST3500418AS (9VM79Z6S), drive, showing error...
If you are getting errors from the hard drive diagnosis, the solution is--replace the hard drive. Don't mess with it. You can install the defective hard drive as a second drive and possibly lift data from it. Keep messing with it and you may lose more data.
Jul 27, 2011 | Computers & Internet
Good morning I have error cord my computer (BIOHD-5) Pelase help me
Here is a thread in a forum that talks about your error. It seems to be a Hard Drive Error. Might need to replace it.
http://h30434.www3.hp.com/t5/Desktop-Hardware/BIOHD-8-amp-BIOHD-5/td-p/304733
Jun 08, 2011 | Computers & Internet
Computer won't boot, reading BIOHD-2 error code.
There are 3 step to repair biohd 2 error
If you got biohd 2 error then there is a 94% chance that your computer has registry problems. To repair biohd 2 error you need to follow the steps below:
* Step 1 - Download a biohd 2 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair biohd 2 error.
Jan 02, 2011 | HP Computers & Internet
We have an hp pavilion with a BIOHD-B error...any suggestions?
BIOHD-B or 8 is Basic Input Output Hard Drive, this is a sign that your hardrive is on its way out, and you need to back up all of the contents as soon as possible.
The faults that cause this error are generally the drive electronics not reading and sending the data properly, or the phisical working of the hardrive not reading the data properly therefore not sending in correctly. The way to check for this is if you hear any slight clunking or clicking noises coming from the harddrive when in use, at the moment they could be quite quiet and hardly noticeable, but will progressively get worse.
My advise is to back up the drive and try a low level format, and see if that fixes the problem or buy a new Hard drive. You can download a low level format tool fron this link:
http://hddguru.com/content/en/software/2006.04.12-HDD-Low-Level-Format-Tool/
Apr 02, 2010 | HP Pavilion a6700f PC Desktop
Mar 24, 2010 | HP Computers & Internet
Biohd-5 Error upon running diagnostic. How to
1. Restart the computer.
2. Keep tapping the F10 key when the HP logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Aug 04, 2009 | HP Computers & Internet
Error code:BIOHD-8
Rebooting forever is either memory fault or the HDD have corrupt system files. From the BIOHD-8, it sounds like HDD issue. Try download "HDD Regenerator 1.51" CD ISO, burn to DC and scan to whole Harddrive. This nice software is designed to recover corrupt/bad sectors. I had a friends PC falls into this case. 1 bad sector was found and recovered within 2GB from start where most Windows system files are stored. Then reboot and windows do a chkdsk automatically, and resolved!
Apr 16, 2009 | HP Computers & Internet
How to fix Hp slimline Error Code BIOHD-5
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
Mar 09, 2009 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
