Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman 17 HP 42" mower. After moving some objects, I restarted mower to continue cutting. On engaging the blades, the mower shut down. How do I isolate which safety switch or relay that is responsible?. I am not that knowledgeable with DC wiring. Terry
  • trmoyock Sep 14, 2010
    Guru Sailer,
    The model # is 917.271132. I posted this with the original question I submitted.
    Thanks
    Terry
  • 1,868 Answers
Hello! I'll need the Sears Model #...Example...917.xxxxxx
Guru...........Saailer
Posted on Sep 14, 2010
  • David Burbee
    David Burbee Sep 14, 2010
    Hello! Here is a component/harness diagram...Item #16 (two) are interlock switches...Located on the right side...Also, Interlock switch (w/plunger) under seat...One or both of part #16 is my top choice...Examine wiring and connector...Check switches w/ohm meter...To view parts go to ...
    http://www.searspartsdirect.com
    Guru...Saailer
I have a new switch and it continues to shut off when the brake is let off.
Then its probably not the switch. No idea which mower you're talking about but most of them have several cut off switches. If the one under the seat is not working (ie it thinks there's no one sitting on it) then when you let the brake off it will shut off the engine. The same goes for the blade engagement switch. If you're lucky the same switch will be used everywhere so you can use your new switch to check each one in turn. Good luck.
Apr 13, 2015 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
306 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
