Question about Panasonic Televison & Video
Hello. I purchased a panasonic tv in germany and now am in US I would like to use it here in US, what do I need to do in order to convert it for US? Adapter? Converter? Is there a switch on the TV? Thank you
    Novelist:
  • 169 Answers
Check the manual for the tv, it may be dual voltage if not then you need a transformer, to stepup from 115V to 230V (nominal voltage). It may have problems with the TV signal as well, as the US is different to europe. Again check the manual first.
cheers
tech240
Posted on Sep 13, 2010
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
I HAVE A PANASONIC KX-TGA402 CALLER ID NOT WORKING
I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
Jun 14, 2012 | Panasonic Lands Phones
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Can I manual convert my TC-26LX85 from NTSC to PAL from time to time?
Hello fabulouspr,
You would need NTSC to PAL video digital converter box. Check your electronic stores that sells TV's, if not search for these online to purchase. Good luck.
-Joe
Aug 28, 2011 | Panasonic TC-26LX85 26 in. LCD HDTV
I have a avol tv from germany, i am in the US and tried to hook up tyhe tv. Everything works except it is in black and white and fuzzy. ive tried messing with the settings but nothing is working. Do i need...
aoconnor733,
It looks like you've run into a problem with the way TV signals are formatted around the world.
Unfortunately there isn't just one standard, but three!
Even worse, the standard used in the US is not the same as the one used in Germany and they're not compatible.
However all is not lost as NTSC-to-PAL and PAL-to-NTSC converters do exist. You're probably best advised to visit your local electronics retailer (Best Buy or equivalent) and ask them to help you find something that's most appropriate for your audio-visual (AV) set-up.
Failing that, type "NTSC PAL Converter" into Google Shopper and see what it suggests.
Kind regards,
Talyene
P.S. If you're interested, you can learn about the different standards by clicking the links below.
[Germany - PAL B/G] ' [USA - NTSC M]
Mar 03, 2011 | Televison & Video
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Analog or Digital?
This TV is analog and will need a converter box when Analog TV is turned off in 2009.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Panasonic CT-20D11 20" TV
Converter box trouble
hello no the only thing the box does is it takes digital signal and convert it in analog signal and cannot do any hurt your tv at all u will be just find marty
Oct 14, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Televison & Video Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
