Question about Panasonic DVD-RV32 DVD Player
How do I connect up my Pan DVD RV32. The TV has input and the DVD player output. That is OK but the cable box has output only. Don't I need to play thru the cable box? Thx, Ron Baty
  • Panasonic Master
  • 11,800 Answers
No, each unit should have their own separate inputs on the tv -  you should never send the signal from one unit thru an other, this causes a loss of image quality.
And in any way you can't do it, modern units only rarely allow it and cable boxes never did. Plug them separately - each one in separate AV inputs and select then form the Sources menu.
Posted on Sep 13, 2010
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
How do i connect my dvd rv32 to my sony tv?
It will depend on your TV's inputs. The included cable is a composite A/V cable. This will work. Match the RCA plugs on each device (yellow to video out on the DVD player, video in on the TV; white and red audio go similarly). Alternatively, you can get and use an S-video cable.
For a better picture if your TV has Component video, get a Component video cable (this has three RCA jacks colored red, green and blue on each end) and then use that. You can get a separate audio cable that only has the red/white RCA jacks (or use the composite video with the yellow video jacks dangling).
If your TV doesn't have Composite video inputs, you need a RF modulator (Composite to RF converter). These are available at many sites, including Radio Shack.
I hope this helps.
Sep 06, 2010 | Panasonic DVD-RV32 DVD Player
How do I connect my dvd to my tv???
connect component{red, green, blue} cables to corresponding color on back of tv or yellow, red, white cable to back or front of tv and select input on remote. May be component labeled or video 1, 2 and etc...Make sure dvd player is turned on first.
Aug 04, 2009 | Panasonic DVD-RV32 DVD Player
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Panasonic DVD-RV32 DVD Player Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
