Question about GPS
Hi, My Garmin nuvi 265 T keeps losing power, I've tried to reset it , it starts all over again. Betty
    Genius:
  • 1,478 Answers
I will suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem. But if the problem still persist,
Another thing you can do is click/ type this link below and run the "updater" This will update your systems firmware: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Take care.
Posted on Sep 13, 2010
My garmin 265w doesn't start it just turns onto the garmin logo and that is a half screen
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Sep 26, 2011 | Garmin nuvi 265 Car GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
My gps will not turn on
Hi undten,
I wonder what's going on with all the Garmin reset and failure to powerup problems during the last few days...it must be the water...
Try these steps for powering up and resetting your unit.
The Garmin Nuvi 265 and most other 200 series GPS receivers are normally reset as follows:
The reset button is located on the right rear-backside of the unit. Press a blunt non-metallic object or a cut off toothpick into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by sliding the Power key to the left for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Let me know how this turns out, and if I can help you further.
Regards,
Bill
09-19-10
Sep 19, 2010 | Garmin nuvi 265 Car GPS Receiver
Hi i have a garmin 265 only 4 weeks old. i have lost all side roads and the navigation is well out. says im on the road next to me. i keep loosing gps signal also. any solutions??????????
I can help you reset and fix your Garmin Nuvi 265W.
Losing gps signal and poor tracking are indications that the firmware / system software inside your GPS need updating.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Mar 21, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
on Apr 16, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi 265 will keep shutting down and rebooting while being used. any suggestions, it is just over 1 year old and this happens whether on battery power or if connected to DC power
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 01, 2010 | Garmin Nuvi 265W GPS Receiver
How delete the home phone number
I can help you edit your Nuvi 265 home phone number.
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
Dec 24, 2009 | Garmin nuvi 265 Car GPS Receiver
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin Nuvi 265 GPS wont recognize satelite
Look near the SN # and press the reset button.
Jun 14, 2009 | Garmin nuvi 265 Car GPS Receiver
GPS Logo
14 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
