Question about Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever ....
Looking for a deverter valve for my shower; - Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever ....
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Call toll-free 1-800-456-4537
Posted on Sep 14, 2010
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
How do I take apart a Delta Monitor Shower Handle
Take a look at this link:
http://www.ehow.com/how_6155493_replace-delta-shower-valves.html
Your valve may vary somewhat but this should give you a good start.
Apr 02, 2011 | Delta & Single Handle Shower Faucet
How do you adjust the hot water on a shower deverter
Diverter valves don't regulate the temp at all they are used with a standard shower valve that regulates the temp and the diverter selects the shower head/body spray/Rain head or whatever configuration you have. This valve can't be used on it's own.
May 25, 2010 | Delta Plumbing
Water start leaking under the house when you pull the deverter up to turn the shower on, its floods out bad!
I'm assuming the leak is in the wall somewhere between the on/off lever or knob and the shower head. It is a good chance that it is the mixing-valve. It could also be where the shower head screws into the drop-eared 90*. If it is the mixing valve, it is either ruined, or a bad seal that might be replaceable. If it is busted piping the wall will have to be opened up to replace it. Good chance that the arm to the shower head is leaking at the threads where it screw into the wall. Good luck.
Mar 15, 2010 | Delta RP17453SS Standard Diverter Tub...
When I turn the water on for a bath only water
the water deverter that makes water come out the shower head is probably in need of repair. or replaced.
Dec 04, 2009 | Moen & One Handle Tub & Shower Faucet
Attachment for airconditioner
THIS DEFLECTOR IS A CLEAR PLASTIC THAT DEVERTS THE AIR FOR FLOOR VENTS LOOK ON THE NET FOR AIR DEVERTERS NOT VERY COMMOND BUT CAN BE FOUND
Aug 08, 2009 | LG LP6000ER Air Conditioner
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
Replaced moen 2225 cartridge leaks when valve is turned on
is this the single handle model? if so simply remove handle, plate, then pull the clip out with a pair of needle nose (after turning main water off).
the valve assembly will pull staright out with moderate force. sounds like one of the small o rings got pinched so it may take a good pull.
make sure to look inside valve housing for foriegn debre. clean it out good. i like to turn the water on for a few seconds before i put the new valve in to blow out any stuff that might cause problems.
Mar 07, 2009 | Plumbing
Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever .... Logo
66 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
