Question about LG Computers & Internet
I have a lg flatron w2061tq flat screen monitor and when i turn on my computer the screen says check signal cable and wont go to any other screen it used to do this just when it went into idle mode and now it wont go away what do i do?
3 Suggested Answers
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
rmoseng
  • 77 Answers
SOURCE: I can't get a signal between my PowerMac G5 and my
First we need to know your G5 and monitor are working, independently. Test these items first on known good computers and monitors. If they show working then;
If your G5 is per 1997 then it may be a true compatibility problem. If 1997 or later, then it could be one of several problems.
1. video card not working or not powerful enough or overheating
2. G5 power supply issues
3. video card may need to be re-seated
4. 3rd party RAM compatibility issues
5. try by resetting the PRAM
6. The monitor may have the brightness and contrast set to BLACK
7. The G5 DVI output may be off or failed.
8. You can try this fix;
Go into System Preferences > Displays > Options (on the 2nd display) and selected "Disable Power Button". Problem solved, if inelegantly.
OR
change the other settings for displays.
9. Using the on-screen settings on the monitor, change to the lowest resolution, then if visible work your way up until it goes blank again.
See some supporting info here:
http://support.apple.com/kb/TA27012
and
http://support.apple.com/kb/HT2707
and
Here is you manual:
http://manuals.info.apple.com/en_US/PowerMacG5_UserGuide.pdf
Good luck
Posted on Dec 14, 2009
My ps3 wont display on my LG monitor using hdmi cable?
check for 720p setting if 1080 p may be to high and will blank out screen
Mar 23, 2013 | Hannspree 22" widescreen LCD Flat Panel HD...
My Flatron W2061TQ has a greenish blue hue that is not going away when i calibrate the color...
most likely the vga cable on the monitor or the computer is just loose. The VGA cable is typically blue in color. The monitor likely only has 2 cables in it, a power cord and a vga cable. So check that first and make sure it is tight. Now you need to check the computer and look for the same cable you saw on the monitor but this time on the computer. Make sure it is tight. There are 2 screws, one on each side of the connector. They should be hand tight to ensure they dont come loose.
Sep 20, 2010 | LG Computers & Internet
LG flatron w2061tq unwanted standby power saving mode
Go to "start>settings>control panel>Display>Screen saver>Power>
Turn off monitor : Never
System Standby : Never
I have tested and its working fine.
Thanks,
Viju
Apr 08, 2010 | Computers & Internet
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Computers & Internet Logo
222 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
