Question about Dryers
I have a Kenmore Electric Dryer Model # 86681100. Recently after it was in the dry cycle it would turn off after about 20-30 minutes of dryng. Sometimes it would turn right back on and other times I would have to wait for it to I guess cool down. I took off the back hose and vacuumed out the lint hose and it does not seem to have helped. Now when I push the button to start it, sometimes it starts, sometimes it makes the noise like it is trying to start but does not and then sometimes it does not at all. No noice or anything. Any suggestions before I spend a lot of money to get a repair man to look at it. Thanks so much for any insight.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Kenmore 120V portable dryer only gets lukewarm
Sometimes the venting in the dryer needs ton be cleaned out as it plugs up and the high limit thermostat makes it short cycle on the heat cycle.
Mar 20, 2010 | Kenmore 82722 Electric Portable Dryer
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
Jun 21, 2017 | Kenmore 659 Electric Dryer
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 110639101
check for blocked vent tube.You should have a very strong flow coming out.If it is weak it will run badly.It is a common call.If its not weak air flow than run the dryer for at least 20 minutes.Open the door and if has no heat inside .......change the split coils. Please Rate This !!!
Sep 15, 2008 | Kenmore 62602 Electric Dryer
Sears Kenmore Dryer #86681100
I took the top off of the dryer to access the door switch. Took the number off the part and went to Trible's appliance parts and got a replacement. Works fine now.
Mar 30, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
176 people viewed this question
Top Dryers Experts
