Question about Krups KM7000
I want to change the water heater in a Krups KM 7000. I have the three phillips-head screws and the one triangle head screw out, but I'm not sure how to open it up from there.
  • 2,272 Answers
You will have to remove all the screws out.But some screws are triangle shaped and for that you will require special tool to loosen that screws.Once the screws are removed.The top cover will get easily lifted.Once you remove all of the screws from the underside of the unit, the hard plastic bottom slid right out. Note that there are more "hidden" screws under the little rubber feet.You'll have to pop the rubber plugs out of their sockets to reveal about 5-6 more screws.The internals of the KM7000 seem pretty basic. There's a length of flexible orange tubing that connects the water reservoir to the heating coil (and the hot plate!), then upwards to the brew-pot. A tiny circuit board connects the LCD display to the rest of the unit. here's how the machine brews coffee. Water from the reservoir flows through the orange tubing into the heating ring, connected to the hot-plate with a little thermal adhesive. From there, the heating element heats the water which forces it upwards through the rest of the orange tubing and into the brew-pot. To see the fig of orange tubing.click on the link below:--- http://mark.koli.ch/2010/03/23/on-the-operating-table.jpg --------- For more detailed help click this link directly:--- http://mark.koli.ch/2010/03/fixing-broken-krups-km7000-coffee-maker-triangle-head-tamper-proof-screws-too.html ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
When draining the machine makes noise
If there is a back panel on the machine you can access it from there, if it has a enclosed back then you will have to lean the machine backwards against the wall to get underneath to access it. The pump has two wires attached to it make sure the power is off & lead removed from wall before you unplug them otherwise you get zapped. The drain pump is held into the pump casing/housing by three Phillips head screws. Undo the screws remove old pump and replace with new pump, make sure rubber seal is on the new pump before installing. You will need a torch & a Phillips head screw driver.
Sep 30, 2015 | LG WM1814CW Front Load Washer
Nespresso d300 leaking
The disassembly is a bit tricky as there are some screws with oval heads that require special tooling.
The web site below has tons of useful information on how to do it and where to find the special tool for the oval-head screws.
http://maultech.com/chrislott/blog/20100627_nespresso.html
The tool is available on ebay for about $10.
http://www.ebay.com/itm/Nespresso-Krups-Service-Repair-Tool-Open-Security-Oval-Head-Screws-/121114184054
I managed to disassemble it by cutting a slot for a flat-head screw driver in the oval screws using a Dremmel tool.
Most of the screws that you have to remove are on the back of the machine. There are three special oval head screws + four torx-head screws + two Phillips screws on the top of the machine.
Feb 06, 2014 | Nespresso D300 Espresso Machine
Replace broked water actuator
You will need the new actuator, regular Phillips head screwdriver, putty knife, and jeweler's screwdrivers.
1. Go to this link to view the parts diagram.
2. Carefully peel part #14 using putty knife.
3. Remove 3 screws part #43
4. Carefully remove part # 4. Note, there are fragile plastic arms that snap into place to hold the top of part #4 in place. I used a flat jeweler's screwdriver to apply pressure to the arms so they did not snap off.
5. Once you have removed #4, you will be able to see the top side of the actuator. There are three Phillips head screws which hold it in place. Just remove those screws, install the new actuator, and replace the screws. Note you may need to remove three Phillips head screws holding #8 in place to get to the screws holding top of actuator. Do this carefully or the wiring harness which attached #8 to #38c will pull out which adds extra steps (If this happens, see below).
6. Replace all parts following the above steps in reverse.
7. I used a small amount of contact cement to restick #14 but it was probably not necessary.
If you accidentally pull the wiring harness from step #5 above out, you will need to remove the circuit board cover to replug it. There are 4 tiny Phillips head screws which hold the cover in place. Remove them using a jeweler's screwdriver, replug the harness, and carefully replace the cover.
Apr 30, 2010 | Frigidaire Refrigerators
GE #WHDVH626 Front Loading Machine - Door gasket Leaks, Need to replace gasket, HOW?
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
Mar 12, 2010 | GE WSXH208A Front Load Washer
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Sep 02, 2008 | LG WM-2277HW Front Load Washer
Tool to open the heater
what does the screw look like?
Dec 02, 2007 | Honeywell HZ514 Baseboard Heater
Water in Krups caraffe
look on the bottom for screws holding it together. they may be of the tamper proof design like three slots or just a hex shaped screw. for the hex a standard nut driver will work. for the three slot a special driver is made for it. A torx looks like an allen head screw but with internal star pattern. torx drivers can be purchased.
Sep 10, 2007 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups KM7000 Logo
159 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
