Question about Honeywell QuietClean HFD-110 Air Purifier
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
  • cameron Jul 18, 2013
    both my quiet-clean air filters are also clicking.
    New Friend:
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Posted on Jul 26, 2013
2 Suggested Answers
SOURCE: Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Posted on Sep 26, 2010
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Jul 23, 2015 | Air Purifiers
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
Describe your Sharper Image Professional Plus? Ionic Breeze® QUADRA? GP Silent Air Purifier Problem: We cleaned it, now it makes a noise. How long is the warranty? Any idea what the noise is? ...
Warranty on these units expired on the 30th of May, 2008 when the company's assets were acquired and liquidated by Hilco Consumer Capital, Gordan Brothers, and Bluestar Alliance. All warranties became void with the bankrupt status.
With regard to the unit that you cleaned, I am assuming that you cleaned it the usual way you always have and it is now making a statical noise or a vibrating kind of noise, correct?
While the unit is off, take out the insert, pick up the unit and turn it upside down. You will hear some beads moving from the elevated end moving towards the bottom. Turn it upside down again and let the beads move to the bottom again. After doing this a few more times turn it upright and put the insert back in. You just cleaned the static lines. Turn the unit back on and see if the noise is still present. If so, try cleaning the insert again and after drying, see if the noise is still present. It is usually some dirt present somewhere that causes the noise to persist. If you have completed everything and the noise still persists you need a new insert which you can get on ebay.
Jun 30, 2009 | Sharper Image Professional Plus Ionic...
Clicking noise
after cleaning is it dry. you might want to take apart and see what is clicking wheel or some thing hard to tell since i can't see it. as far as options . check with the manufacture google it check them out on line hope this helps. Tom
Jun 20, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Jan 12, 2009 | Oreck XL Professional Air Purifier
Cleaned the filters and is mking a noise!!!
Get someone with some mechanical sense to get it out; watch what they do. You could have checked the manual or the maker's website, could you not?
Mar 31, 2008 | Brookstone Pure-Ion UV Air Purifier
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell QuietClean HFD-110 Air Purifier Logo
912 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
