Question about Insignia IS 20" TV040919 TV
Insignia TV - no power to the TV set
I have an Insignia TV and it used to work fine till 10days ago. Suddenly it stopped working. The TV does not turn on. THere is no light indicator or anything. Looks like no power to the TV set.
Cld u pls suggest.
  • 1 more comment
  • Anonymous Jun 14, 2008
    Have notice that says no signal-hAS BEEN WOKING FO SIX WEEK. RETURNED TO STORE . tHEY NO LONGER CARRY ITEM. mUST REPAIR.
  • firehozer519 Jul 02, 2008
    Had the same problem. The TV was left unplugged for a long weekend, when I returned and plugged it back in, it was as if the unit wasnt getting power at all!
    Has anyone had a solution for this?
  • toolkitguy1 Jul 03, 2008
    I have the 22 inch version of this TV set. I was watching it and I heard a loud snap. the set turned off and now there is no red led when the set is plugged in but off. Suspect a blown fuse due to component failure. Might be flyback transformer. It sounded like a high voltage snap when it failed,
    but maybe a component like a rectifier could have exploded. I am going to take it apart tomorrow to see if there is any visual damage, and will check the fuse.
2 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: TV does not switch on.
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). It could even be a blown fuse..
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 13, 2008
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
I purchased a 27'',Insignia tv about a yr 1/2 ago, it has been working fine till about 3 days ago, when it decides to shut down by it self. however, when i unplug the tv cord and replug, it comes back on....
To start unplugg it for a few hours, I know it sounds dumb but it will reset the set. If that does work get the TV on a surge protector. It would surprise me if this needs service beyond that, this brand is very service prone
Nov 12, 2009 | Televison & Video
Insignia car dvd player car adapter doesn't work
Your power adapter for the car is not working. Check if there is any voltage output while plugged in.
Aug 11, 2009 | Insignia Dual 7" 16:9 Widescreen LCD...
Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
Aug 06, 2009 | Insignia NSLTDVD26 LCD TV
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Hope that helps!
IrishDruid
May 13, 2008 | Insignia IS 20" TV040919 TV
TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Dec 13, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Insignia IS 20" TV040919 TV Logo
545 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
