Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
My 2100rp says spk when the heat is askied for but does not light
  • 2,272 Answers
If your heater has been installed correctly, operating the heater is an easy task. The upper front panel of the
heater contains the control center that allows you to turn the heater on or off and adjust the temperature settings
for the pool or spa. The temperature range is 65°F (18°C) to 104°F (40°C). The heater with the electronic control
option also has a manual switch located on the right cabinet side to allow you to turn the heater off.
If pilot burner does not light:-------Check gas supply, gas
line size, gas pressure.Also check for insects or debris in pilot output. "SPK" will be displayed until spark is lit.Max time 2 minutes.
Check out.Keep updated.
Posted on Sep 13, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Raypak 2100 fault
It sounds like your ignitor may be out. Everything else is good in the safety loop and the heater wants to fire. The last step in the process is the ignition of the main burner. Are you hearing a ticking sound? If not the spark is not being produced.
Apr 12, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
When we tried to light the heater the CFH shows, then I get a SPK which stays on for aroound 1 minute, then I get a LO. The heater never lites.
The CFH is a Call For Heat.
The SPK tells you that it is creating a spark for ignition.
The LO tells me that you are on propane.
The fact that it doesnt light tells me that either the ignitor is not sparking, or that there is no gas, or an incorrect gas supply.
If this unit is installed with flexible gas line, replace this with rigid black pipe or a larger flex line.
Oct 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I can not find out the color meanings. Power, ground and such please help!
Ok,
Power 12V + : Yellow
Ignition Switch : Red
Amp Turn on : Blue / White stripe
Antenna : Blue
Ground : Black
Illumination :Orange/White
Dimmer : Orange
Left Front Spk + : White
Left Front Spk - : White/Blk
Right Front Spk + : Gray
Right Front Spk - : Gray/Blk
Rear Left Spk + : Green
Rear Left Spk - : Green/Blk
Rear Right Spk + : Purple
Rear Right Spk - : Purple/Blk
Hope this is helped you,
Good luck.
May 21, 2010 | Pioneer AVIC-N1 Car DVD Player
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
I need the diagram for 1993 honda accord for radio i am installing a jvc cd player and i dont have the right adapter so i cut the origanal plug and now need to know the color codes for the wiring
this the wiring for that car--
constant power-white/green
ignition--white with red
ground-black
dimmer-red/black
left front spk-blue with green-+
left front spk-ghray/black -
right front spk-red/gree-+
'' spk-brown/black-
right rear spk-red/yellow-+
'''''''''''''''''''' spk-brown/white-
left rear spk-blue /yellow-+
'' spk-gray/white -
antenna you done need you antenna is in your window
Jun 25, 2009 | Car Audio & Video
Nokia 1112 phone aski ng inter sim card
There is some problem near the sim holder port ...
i think there is loose contact near the sim holder port so just open the handset and refit it correctly ...
do it if you are good at opening the handset ....
if needed replace the sim port holder ....
if not contact the technician he may take service charge from you ...
regards
-Dileep
Dec 26, 2008 | Nokia 1112 Cellular Phone
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
189 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
