Question about White Sewing 1418 Mechanical Sewing Machine
The needle will not move up and down - White Sewing 1418 Mechanical Sewing Machine
  • 161 Answers
Can you move it by moving the hand wheel ? Might need a thorough clean and oil, look for thread jammed in a guide; good luck
Posted on Sep 13, 2010
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
Why is my needle not moving?
open the end cover of the machine and see if the needle shaft is moving up or down
it is possible that a screw has come loose or an arm has broken
May 14, 2015 | Sewing Machines
Bernina 180 needle bar won't move up and down
This could be the needle bar clutch. Turn off machine. Unplug machine. Remove needle. Turn hand wheel in normal rotation 1/4 turn. Gently move needle bar up and down by hand you should feel a click and the needle bar will not move up and down easily now. Restart machine and test. If it works all is good. This is a result of the machine requiring professional attention. If you use basting stitches it will likely unclutch again.
Jun 15, 2014 | Bernina Sewing Machines
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
Needle no longer moves up and down but the engine whirs
sounds like the needle is bent replace the needle
Dec 25, 2013 | Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
THE NEEDLE WILL NOT GO UP AND DOWN
if the needle bar doesn't move the needle up & down then the machine needs to be serviced, to find out why it isn't moving
May 01, 2012 | Bernina Sewing Machines
My needle and shaft won't go up and down. I have tried using the hand wheel to move the needle but it still won't move.
hi there
1- losse screw for needle bar and try to move machine by hand if machine realease means needle bar jam and need to change with lower bushing.
2- remove stoper for bobin case and move machine if realase means there isthread on hook and need to remove it and re adjust timming between needle bar and hook again.
BEST REGARD
ashrf abozid
aabozid@hotmail.com
Nov 10, 2010 | Sewing Machines
My needle does not go up and down.
You need to check the needle bar first of all to see if you can move it up and down by hand, if you can then the screw on the needle bar may have come loose, or the very worst situation could be a broken takeup lever
Jul 05, 2010 | Bernina Artista 170
White Sewing 1418 Mechanical Sewing Machine Logo
29 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
