Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have rca d52w20 the tv power button lights up and blinks then powers off. I unplugged it last night and waited a while and plugged it back in and it worked. Then today same thing but no luck getting it to power back up. What else can I try? Some one suggested it might be in sleep mode but how can I tell if there is no picture? No way of getting to the MENU screen.
  • RCA Master
  • 8,457 Answers
U take out the a/c power plug out of the power sourced,replug it back after awhile it work as normal again right?Before right? This problems it the cause of those dying capacitors on the DM power supply board.These capacitors are alway bulges up on it tops or or puffing up on it tops,they're leaking gases and dying.U know basic electronic's,have tools and know basic soldering?Take out the DM power supply board check for these dying about to dead capacitors,replaced them.Tv should work again.The website Tvrepairworld.com,put together these capacitors as kit.Buy it replaced these dying capacitors,power to tv will return.
Posted on Sep 13, 2010
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The power button light blinks a few times but no power afterwards. RCA D52W25 is dead. I lightly shook the TV last night and it worked until this morning.
These units are famous for loose solder connections at the high voltage transformer and for bad capacitors in the power supply. Have a repair shop check it out for you. You have to remove the Deflection PCB to do these repairs. Thanks
Oct 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
No power/button blinks
these tv are easily repaired
if you dont know tv basic,
forget it
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
