Question about Sony KP-51WS500 51" Rear Projection Television
The picture looks doubled with green and blue. Is this a sign of a bulb burned out? Can you look at the bulb and know which one it is?
    Top Expert:
  • Sony Master
  • 14,553 Answers
Most likely is it is a convergence problem---this model uses two of the STK-392-560 IC'S for this---total parts cost should on EBAY be under 25 dollars.
See attached photos and if your set looks ANYTHING like them, it is a convergence problem.
Let me know if you have questions with a comment here--I am here to help.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 13, 2010
  • malueg2806 Dec 09, 2010
    Is changing STK-392-560 IC'S something a fairly capable DIY'er can accompolish.
Tv is yellow orange color what is problem
The model indicated does not have a "bulb" as it uses 3 picture tubes.
Examine the picture with color set at zero---stand back and look= if the screen has a mostly yellow (all or part of the screen) you have bad Glycol in the blue picture tube(if need explanation ask) and a look in the lens of the Blue tube will confirm this.
If able with back off and a small mirror look in each lens--red picture, green picture and blue picture.
If the Blue looks like a floodlight with little or no image--bad glycol in that tube.
Jun 16, 2012 | Samsung HCN5527W 55" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Philips projection - no picture - 51PW9303
there is a lamp to generate sound bad because this is a short-circuit it is recommended that a technical review
Aug 20, 2009 | Televison & Video
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
The picture is red, does this mean a bulb has burned out ?
there will be three bulbs, red blue and green. if the display is red, than one of the contrasting colors is shot, more likely the blue.
Jun 18, 2009 | RCA D52W19 52" Rear Projection Television
Blue bulb is lit but no picture
the messed up colors are probably from a burned out convergence chip. not too pricey to fix.
Feb 17, 2009 | Philips 55PW9363 55" Rear Projection...
Samsung projection tv
This is most likely a convergence problem. Does the picture look like 3D? If so, please confirm that the model is PCL541R and I'll rpovide additional details and instructions.
Dan
Sep 24, 2008 | Samsung PCL541R 54" Rear Projection...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
No Blue
Nope you did it! Its the blue tube. Go to http://www.samsungparts.com and enter your model number and look up the tube. I did one last month for someone at techlore.com Are you the same person? Oh well look it up but do you have the proper equipment to replace this tube, as its very dangerous to handle!! They have a tendency to implode and then explode if not handled right.
Sep 02, 2006 | Samsung PCJ522R 52" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
661 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
