Question about Swift Optics
Our Swift model 761 8x42 is missing the focus knob. Can you fix it?
  • mattana2 Sep 14, 2010
    Yes, the info was helpful. Two big toes and two thumbs up.
  • 8,197 Answers
Sorry we do not repair. Send them in. Swift will fix them at no charge.
Repair and Service
For Binoculars over 15 years old, that are missing parts, please send your product to our repair department at:
Swift Optics Repair Center
C/O Nicolas Crista
25 Crescent Place
Hanson, MA 02341
781.294.2039
For Binoculars less than 15 years old and Spotting Scopes, please send your product to our repair department at:
LSSTNR
1927 Richmond Ave
Houston, TX 77098
713.529.3551
Check out their website for what to do. Swift Returns (http://www.swiftoptics.com/support/repair.php)
Good Luck, Please accept the answer and rate 4 thumbs up
Posted on Sep 13, 2010
Maruti swift gear
I am also looking to remove the gear knob on my maruti swift (2009), but the thing is not ready to move a centimeter.. Did you finally succeed in pulling it out. Please update !
Jul 19, 2012 | Cars & Trucks
Hi, Original focus knob fell off my atx 70 and now the 'focus rod' goes inside the telescope instead of moving front part. Is there any way to fix it?
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
Apr 06, 2011 | Meade ETX-70 (240 x 70mm) Telescope
The stage slides down on its own and the view gets out of focus.
Just inside the coarse focus knob you will see a "chrome" ring with holes it it. That ring needs to be tightened just a bit. It will make the coarse focus knob stiffer so tighten only enough to stop the downward drift of the stage. A funny looking tool should have come with the scope. It is used to adjust this "tension" ring.
Oct 22, 2010 | Swift M2251C Monocular Microscope
Stage slides down after focusing
There is a tension adjustment for this. It is located on the coarse focus knob which is on the same side as the switch. It looks like a chrome ring with about 3 holes in it. A strange looking tool should have come with the scope. It is designed to fit into these holes and allow you to adjust the tension on the coarse focus knob. You need to tighten it just a little bit. Not too much or you will have trouble operating the coarse focus knobs smoothly.
Jul 08, 2010 | Swift M2251C Monocular Microscope
Swift microscope no 634008 having problem staying in focus when switching magnification
First, a scope of this grade will not be completely in focus as you move from one magnification to the next. But it should be close enough that you do not loose your point of interest.
Be sure you are not pressing down on the stage specimen platform as you change magnifications. It is very sensitive to pressure. Also, be sure that the coarse focus tension is tight enough that the platform is not drifting down imperceptibly as switch magnifications. Look through the scope and watch if the image goes out of focus while you are watching it. If so, you have what is called "stage drift". This is corrected by tightening the tension on the coarse focus knob.
The tension adjustment is on the coase focus shaft. It looks like a chrome ring with about 3 holes in it. There should have been a strange looking tool that came with your scope. It is used to adjust the tension. If your specimen is "drifting" out of focus, simply tighten the tension ring a little bit at a time until the specimen no longer goes out of focus. Do not get it so tight that it is not easy to operate the coarse focus knob.
May 22, 2010 | Swift M2251C Monocular Microscope
There is some sand or dirt under the focus knob that makes a noise when the knob is turned. How do you take the knob off to clean . Thanks
There is a central aluminium decal on the focus knob. CAREFULLY prise it off using the tip of a sharp knife trying not to distort it (it's hard to panel beat a small bit aluminium!). Once off you should see a central screw or two screws that hold the focus wheel in place. Remove the screw(s) and the focus wheel noting the orientation of the focus wheel to the body. Use a dot of Liquid Paper to show registration. You can then clean around the focuser and the inside of the focus wheel before reassembly.
Jan 03, 2010 | Swift 10x42 HCF Viceroy Waterproof...
Missing and check light problem
have them check the timming belt. also have autozone scan for free to check the codes good luck
Sep 24, 2008 | 1990 Suzuki Swift
Focus?
The C8 optical tube has a very large focal range. It should be capable of focusing on objects from 15' to infinity. To focus on object at infinity you have to move the primary mirror foward. You do this by rotating the focus knob CCW. Rotate the knob CCW until it comes toa stop them slowly bring the mirror back by rotating the knob CW while viewing the object. It will snap to focus so don't move too fast yor you'll miss it.
Jun 25, 2008 | Celestron NexStar 4 SE Telescope
Telescope knob
Still not enough information, but taking a stab at it, I'll assume you mean the pinion rod that goes between the focus knobs, and engages a gear rack on the focuser. There are locations where they can be purchased, and you would need to provide the OD and pitch (teeth per radian) to match.
Try: http://www.pinionrod.com/ as a source.
Jun 13, 2008 | Optics
Focus knob screw
Not enough information to answer question.
Jun 04, 2008 | Optics
Optics Logo
593 people viewed this question
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Tom Chichester
Are you a Swift Optic Expert? Answer questions, earn points and help others
