Question about Gateway Computers & Internet
My computer monitor frequently blacks out while in use. Gateway troubleshooters sent me an update for the video drivers, but it did not solve the problem. I get an error message stating "not optimum mode. recommended mode 1280x1024 60hz" I have corrected this even prior to the driver download. The blackouts are not as frequent, but still occur after about an hour on the computer. What can be done to correct this?
  • sperry985 Sep 16, 2010
    Yes, I have checked the screen saver settings. The screen saver is presently on 1024x768 at 60 hz which was recommended by another tech who said 1280 x 1024 was too much for my screen size (18"). It works and looks better on the current setting, but still blacks out.
    Sergeant:
    Champion:
  • 251 Answers
Have you checked your Screen Saver settings?
Posted on Sep 15, 2010
I just bought a new monitor and I still have double images, I tried changing cable, checked connections and updated drivers. what else cpould it be Thank you
If you replaced the monitor due to the image problem, then it is more likely that you a problem with your video card or video card drivers. I would try to reinstall the video card and see if that solves the problem.
Apr 21, 2011 | Gateway FPD2275W LCD Monitor
My monitor flashes on and off while I am working.
There are lots of reasons why it can shutdown, but happerlly none should be serious. It may be that the B+ or Power supply is too high, look for a pot near the power supply and try turning it down a bit. Also the x-ray protection may be too high, look for the X-Ray pot, found near the FBT, turn that down too. I assume your a tech and know how and where to be carefull.
card settings are too high and your monitor cannot handle the settings. One way to confirm this is to boot into SAFE MODE and see if it still happpens. If it does not, then its the video card settings. If it does, then it indicates that the monitor is in need of service or replacement.Turn down the resolution and color depth settings all the way, and then increase them incrementally until it is as high as it can go until this problem starts happening again. To adjust video settings, right click anywhere on the desktop and select Properties. Then go to the settings page.If the display does not stay active long enough to make these changes, then boot into SAFE MODE and delete the video adapter from the device manager. Upon rebooting the computer, the video adapter will re-install itself with low default settings.Is the correct monitor selected in your display settings?Make sure that the correct monitor appears in Display properties. If the wrong monitor is selected, Windows might not use the full capabilities of your monitor, and you might be restricted in your choice of screen resolutions.To check your monitor selectionOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Monitor tab. The monitor that is selected for your computer is displayed under Monitor Type.If correct monitor isn't listed, click Properties. Click the Driver tab, and then click Update driver. After the Hardware Update Wizard starts, click Install from a list or specific location, and then click Next. Click Don't search. I will choose the driver to install, and then click Next. This provides a list of monitor manufacturers and models.In Manufacturers, click the manufacturer of your monitor, and then in Models, click the model name.
If your monitor isn't listed, click (Standard monitor type) in Manufacturers, and then choose the most compatible setting for your monitor in Models. Click Next, and then click Next again. NoteTo open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.Are you using the wrong driver for your display adapter? ImportantThe following procedure might require you to restart your computer, which will close this troubleshooter. If possible, view this troubleshooter on another computer while you perform the steps on the computer you are troubleshooting.To continue troubleshooting if no other computer is availableRight-click the page displayed on your screen, and then click Print.
    1. Follow the steps in the printed copy of the procedure.
    2. After your computer restarts, reopen this troubleshooter and answer each question as you answered it initially.When you reach this page again, answer the question at the bottom, and then click Next.If the wrong driver is specified for your display adapter (video card), you might have problems installing your monitor or increasing the video resolution above 640 × 480 with 16 colors.To find out whether a better driver is availableOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Adapter tab. Click Properties, click the Driver tab, and then click Update Driver.Click Install the software automatically (Recommended). Follow the instructions in the Hardware Update Wizard to search for a better display adapter driver. Restart your computer if you are prompted to do so. NoteTo open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.You might be able to download an updated driver from Windows Update. To go to the Window Update Web site, click Start, point to All Programs, and then click Windows Update. If an updated driver is available, follow the instructions for downloading the software to your computer and installing it. If the driver is not installed automatically, use the procedure above to locate and install the driver on your computer.
Does installing the correct driver for your display adapter solve the problem?Does Windows support your display adapter?To determine whether your display adapter (video card) is supportedCheck the Windows Hardware Compatibility List (HCL) in Help & Support.If your display adapter is supported, the HCL might include notes about it or links to updated drivers. Download any new drivers that are available. NotesIf you follow this link, when you return to this troubleshooter you will have to start over from the beginning and answer each question as you answered it initially. You must be connected to the Internet to view the HCL. If you do not have Web access, contact the manufacturer of your display adapter to find out if it is compatible with Windows XP. If your display adapter is not on the HCL, or is listed but is not shown as being compatible with Windows XP, Microsoft does not provide support or drivers for it. Contact the adapter manufacturer, or visit the manufacturer's Web site, to obtain a driver that is compatible with Windows XP.
Does Windows support your display adapter?If it is supportedDecrease the hardware acceleration setting. ImportantThe following procedure might require you to restart your computer, which will close this troubleshooter. If possible, view this troubleshooter on another computer while you perform the steps on the computer you are troubleshooting.
  • To continue troubleshooting if no other computer is available
    1. Right-click the page displayed on your screen, and then click Print.
    2. Follow the steps in the printed copy of the procedure.
    3. After your computer restarts, reopen this troubleshooter and answer each question as you answered it initially.When you reach this page again, answer the question at the bottom, and then click Next.To decrease hardware accelerationOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Troubleshooting tab. Drag the Hardware acceleration slider to the left.
  1. Click OK, and then click OK again.
  2. Restart the computer when you are prompted to do so.
Note
  • To open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.
Does decreasing hardware acceleration solve the problem?
If not resolveIs the BIOS for your display adapter out of date?
The BIOS for your display adapter might not allow a resolution higher than 640 × 480 with 16 colors.
Contact the display adapter manufacturer to find out whether there is an updated video BIOS for your display adapter that supports higher resolution.Does upgrading the video BIOS solve the problem?
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 24, 2010 | Computers & Internet
Screen turns black when tring to play video games
update the display adapter and check with the requirements for the game
if required upgrade the video card
Mar 13, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
Aug 31, 2009 | Gateway SX2800-01 PC Desktop
Black and white screen
I had the same monitor and same problem. Nothing you can about it if your computer works fine... than its not your computer's falt. I got a new monitor. That's the best you can do too mate! :)
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor frequently changes into a series of black and white stripes.
The video board inside that connect this to you vid card is going bad and will need replacment. There is not really much you can do troubleshooting this. Thanks and good luck
May 24, 2009 | FujiPlus FP-568 / 15-Inch / 1024 x 768 /...
Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 15, 2009 | Gateway 7330GZ Notebook
Monitor goes black suddenly
nvdia 6600 requires a minimum of 450 Watts of power to ensure that everything works properly. So if you want to continue using your nvdia card, an upgrade will be necessary.
If you want to test to see if it is the nvidia card, you need to remove the card physically from the system, then boot with the onboard video. This action will eliminate any conflicts between the two video cards. Before doing this you may need to go into device manager and make sure the onboard video card is not disabled.
Jul 26, 2008 | Gateway 838GM (RB838GM) PC Desktop
Video does not work
It sounds like the Lcd inverter board is bad in the monitor
as you turn on the computer if you see no video at all and the screen stays black all the time then the inverter or the power to the inverter is bad.
you need to have the lcd monitor checked out.
the flickering off and on is the usual symptom for this.
Feb 03, 2008 | Gateway Media Center 610XL PC Desktop
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
