Question about Canon PC-940 Black and White Copier
Paper Jam Sign Staying on without a paper jam
    Problem Solver:
  • 5 Answers
Does the printer keep the error even after turning it off then back on? If so, make sure it is on then unplug it from the back and do a hard reset, that should clear the error and reset the printer without actually resetting your calibrations for it.
Posted on Sep 14, 2010
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
Paper jam sign on top of ADF,even when there is no paper jam
Jul 31, 2013 | Toshiba E - Studio 810 Multifunction...
Paper jam
  1. Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Remove the cover from the housing of your Lexmark printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Unplug your Lexmark printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Plug the printer back in, refill the paper tray and try to print again.
Thank you.
Oct 30, 2012 | IBM Office Equipment & Supplies
A warning sign has appeared on the printer, which says: 'Paper is jammed in the printer. Turn off the printer, open the scanner unit, and remove the paper. See your documention'. But There is no paper...
either a sensor broke
or
a small tiny piece of paper is stuck
after removing a jam if the paper tears a small piece of paper can cause the jam error message
Jan 19, 2011 | Office Equipment & Supplies
Paper jam stays on without paper jammed in machine
try this... reset the printer...
Next... reboot the computer... this should reset the printer and the computer and the system...
Oct 25, 2009 | Lexmark X4550 InkJet Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Savin 2513 Jam
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Oct 12, 2008 | Office Equipment & Supplies
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Canon PC-940 Black and White Copier Logo
100 people viewed this question
old marine
old marine
