Question about Dell OptiPlex GX260 PC Desktop
Optiplex 560 Power Intermittent
We have a Dell Optiplex GX560 that is used only occasionally. This is the only Optiplex GX560 we have in house. When trying to power it up recently, it wouldn't power. We did see a yellow light lit, on the motherboard.
After trying to locate a substitute power supply (and failing to locate one), our tech tried resetting some of the cable connections between the motherboard, the power switch, and the power supply. The system powered up, then later wouldn't power up, then did.
Any recommendations on where we might find a replacement skin (power supply, case, motherboard)? I realize this is an old unit, but it's used to build images for our DR site.
  • 1,342 Answers
Try updating the BIOS. Seems there were some advanced power management improvements.
Dell Downloads
The following changes were made to the A04 BIOS for the A06 BIOS: 1) APM issues device commands in SMM. 2) Fixed APM to issue power up/down commands to peripherals in SMM. 3) Turbo/Deturbo switching done in SMM. 4) Implemented <\> Turbo/Deturbo hot key. 5) Password checked after exiting Setup and before OS booting. 6) Fixed the problem with #9 GXE64 Video card losing its video at the end of POST. 7) Fixed the problem with WINICU having General Protection Failures. 8) Fixed the problem with Real Time Clock not being updated correctly when in Power Managed mode.
Posted on Jun 03, 2008
I want to know About Dell OptiPlex 3020 Desktop.
Everything you want to know about a Optiplex 3020 here;_ylu=X3oDMTByaDNhc2JxBHNlYwNzcgRwb3MDMQRjb2xvA2dxMQR2dGlkAw--/RV=2/RE=1418347615/RO=10/
Dec 11, 2014 | Dell Optiplex 3020 Intel Core i3-4130...
IN dell optiplex sx280 model system we are using in this amber power led blinking continuly yellow color because of this not able to boot the system. kindly give the solution for the same
Hi there!
A blinking amber/orange light on the power button of your Dell Optiplex means a hardware failure. If you know how to strip down your computer to basic component, then I suggest you turn on with only the motherboard, processor, memory and PSU. If you are not familiar with this, I suggest you bring the computer to a qualified technician.
Hope this helps
May 09, 2011 | Dell OptiPlex SX280 PC Desktop
My Dell Optiplex 330 does not turn on,there is a yellow led light blinking
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might occur.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
You an use the following link to know how to open the computer tower
User manual
Thanks for using Fixya
Oct 13, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
What kind of video card can you use on a Dell Optiplex gx 280 small desktop pc, with 210 watt power supply?
You can use this type of video card PCI Express x16 DVI video card.
Click this link for more information.
Apr 15, 2010 | Dell OptiPlex GX280 PC Desktop
My dell sx270 optiplex doesnt powerup somtimes after i unplug power supply
Chances are it's going to be slightly oxidized contacts on a supply part, but it's not broken, just intermittent. Some power supplies use relays to supply the voltage, and their contacts can get oxidized. The fix for this is to take it off it's mounting, open it up, and use paper or a very fine emery cloth to clean the contacts. You can also change the relay, if that doesn't work out. It's not something that will hurt your computer, just a nuisance.
Apr 08, 2010 | Dell OptiPlex SX270 PC Desktop
Hi my power in my house went out today. When I got home my computer is off, no lights no nothing. Help
Check if the power cable was properly plug into the power outlet.
If you are using a AVR, or a voltage regulator, double check if the unit fuse was not busted. Due to some power outage and any abnormal power input on your area, the fuse will be the to down cause this parts will be the one absorb the power failure and not directly to the appliance.
Let me hear from you here again.
Apr 06, 2010 | Dell OptiPlex GX520 PC Desktop
I have no sound on my dell optiplex 560. i'm using linux but was the same with xp
If you do not have sound on 2 different operating systems then make sure everything is plugged in correctly and powered up. Make sure your speakers are on and the volume is turned up. the problem is pointing to the card or speakers if 2 operating systems cannot make sound.
Jan 09, 2010 | Dell Optiplex X150 Chassis USB/Audio Board...
I mistakingly switch the voltage to 110v instead 230V
You are going to have to replace it....obviously. Here are some places that popped as having the supply you need. I have never used any of them personally.
Dell Optiplex Gx1 Gx110 145w Desktop Power Supply 5554t
$14.99 used - eBay Dell 11VTW Optiplex GX110 SFF 110W Power Supply (See 1728P)
$35.00 refurbished - Used-pcs.comNEW Dell Dimension XPS OptiPlex Power Supply, 200W, Dell 824KH
$19.97 new - TXcess Surplus
Oct 07, 2009 | Dell OptiPlex GX110 PC Desktop
Does a firmware update for dell optiplex 755 optical drive fix intermittent rebooting issue
dell 755 drivers page
your looking at the wrong firmware
optiplex 755 current bios version: A10 date 6/20/2008
for the CD Drive need to open device manager and check
what brand and model you have for dell used 2 DVD drives
b0a7e29.jpgsony and teac
use the correct firmware on drive, if not the drive will be killed.
if unsure open case and look for name/model on sticker of drive
Jun 23, 2009 | Dell Optiplex 755 Desktop Desktop Computer...
Dell OptiPlex GX260 PC Desktop Logo
386 people viewed this question
Alun Cox
