Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Once set the aqualink works however if a storm or lightning is in the vicinity its loses it's memory and has to be reprogrammed. this is problem since we intend leave house for a period of 3 months; We had it serviced and the tech said to put in a new computer board for $850. What alternatives might you suggest; thank you in advance. Michael Attardo
  • 990 Answers
First try a 9v battery at the box by the equipment. If it programs it's probably just a matter of keeping power to the board when it goes down. You need a new battery at least once a year.
If this dosn't help you may need a new board, but I would spend the two bucks on a battery first.
Posted on Sep 14, 2010
How do you reset the memory on a aqualink rs6 timer
write down all your auxillaries and if you have acuators because when you reset all is gone go to system set up then clear memory button then reset the button on front of aqualink then reprogram
Jul 29, 2014 | Pool & Spa
I cannot figure out in the RS6 menu how to delete a device program. I have two programs for my cleaner and want to delete one. Anyone know?
The best thing you can do is to clear the memory for the system this should be done once in awhile it is like rebooting your computer.
Here are the steps;
1. Press the menu button
2. Now press < button till System Setup is displayed
3. Press enter
4. Press < till "Clear Memory" is displayed
5. Press Enter
6. Press Enter
You will get a message saying " System Memory is being Cleared"
Once it is done the display will go back to scrolling mode
Now reprogram the system as you normally would
You should do this "rebooting" once a year it will make the system run alot better.
Aqualink systems can get a issue called "Ghosting" which is equipment will get programed to run all on it's own. We see it alot in the bigger systems (RS8 and up) for some reason. We are a Jandy warranty center have been for 10 years now.
Hope this helps
Jan 08, 2011 | Jandy AQUALINK RS TELELINK KIT
Garage door only opens from button inside garage not by bour remotes in our cars ( 2 remotes )
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN
Nov 13, 2010 | RTO Automatic Garage Door Closer
All key fobs which I assume operate using a RF function have ceased working....why?
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AGAIN TO TURN OFF LOCK FUNTION.
THIRD REPLACE THE BATTERIES IN THE REMOTES AND THEN REPROGRAM.
HOPE THIS HELPS
May 23, 2010 | liftmaster Chamberlain Garage Door Opener...
I have an Aqualink RS4. I want to delete the 3 programs scheduled under filter pump. How do I do that?  Thanks
The best thing to do is to clear the system memory. Aqualink can have a problem with "ghosting" Things just go on by themself when not programed to. A bad spa side remote can do that to but that is another problem.
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till diplay says " clear memory "
Push star or enter
Push star or enter again to comfrim.
You will get a message "earsing memeory"
Now you can reprogram system
If you want differant run times like a summer and winter timing you can do that with the program groups
Hope this helped
Keith
Jun 18, 2009 | Jandy AQUALINK RS TELELINK KIT
I have 2 sears door opener the remote not workinng we re set the coadswill not open door
IF REPROGRAMMING DOESN’T HELP TRY REPLACING THE BATTERIES IN THE REMOTES AND THEN REPROGRAM.
HOPE THIS HELPS
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Operating instructions for Aqualink RS8 pool/spa combo panel?
To clear the memory
Push back arrow till display says " clear memory "
Push star or enter
Push star or enter again to confirm.
You will get a message "erasing memory"
Nov 18, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
63 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
