I have an audio desktop TSX-130, and the antenna is not sufficient. it fails on many stations. i am unable to find a stronger one. Harold
  • shsh2 Sep 14, 2010
    the connection to the tsx130 is just a single wire. I would prefer to buy an enhanced antenna if it would plug into my unit
  • 11,800 Answers
Remember those rabbit ear antennas? You need one of those - the only thing you need to do is to put it in an good location and use a long 75 ohm cable from it to the back of the unit.
Posted on Sep 13, 2010
  • Azrael SRL Sep 14, 2010
    That connector can be bought even at Walmart for 50c, it's put on the antenna 75 ohm coaxial cable. Whatever antenna you choose to use you will have to buy and install one on it since none have it by default.
I can get am station fine get fm barely
The FM and AM antennas are different types. AM sometimes doesn't even need an antenna. Please make sure you are using the right type of antenna attached to the FM antenna terminals on the back of your receiver. Usually a 6-8 ft. piece of wire is sufficient if you're within 20-30 miles of a radio station.
Mar 08, 2015 | Onkyo TX-SV515PRO Receiver
Not receiving signal from wcyb channel 5 on winegard hd7697 antenna
try installing a tv signal amplifier on the line from the antenna just before the tv. Tv stations put out differing amts of power, one could be stronger than the other.
Mar 21, 2014 | Winegard HD7697 High Definition VHF/UHF...
I have a 2012 raptor toy hauler with a sony multi disc player [MEX-DV2200] and the radio has quit working. It turns on but won't receive any stations. Everything else works fine. Any ideas?
Have you been able to check your connections from the unit to the antenna? If it was working before and then just quit I would start there first, a loose connection or frayed coaxial cable could be your problem, also if the antenna has moved it could be improperly grounded now and unable to receive also, you'll need to check the mounting of the antenna to make sure that it has come lose or built up corrsion. Roughly 80-90% of all radio problems/solutions are antenna/cable/connections based and rarely the radio itself.
Oct 16, 2012 | Sony MEX-DV2200
Radio wont find any stations
tuner IC TEF6901 probably failed - needs new tuner unit that cannot be purchsed!
Jul 06, 2012 | Visteon Car Audio & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
What is sw in cde100
SW stands for Short Wave. You can receive long distance radio stations if you have a good antenna. Try it at night for starters because signal will be stronger.You can pick up radio stations from the other side of the Globe ( Africa /India /Australia etc. ).
Sep 02, 2011 | Alpine CDE-100
Yamaha tsx 120. When ipod is fully charged when playing music,the yamaha unit goes into pause mode and music stops! I've checked its not in sleep mode too!
See one of my other posts re a TSX130 issue that turned out to be some corruption of the iphone. when the OS was changed it cured it.
Try another ipod first to prove/disprove this
When my iphone 3gs was fully charged it used to turn the TSX on playing...OS upgrade cured this too
May be the same issue you have?
AW
Aug 15, 2010 | Yamaha TSX-120BL Desktop Audio System ...
The phono works, but i get no sound when tuner on
This usually means that the tuner is not getting sufficient reception for the station you are trying to listen to.
Receivers come with cheap wire loop antennas try upgrading to a powered FM antenna available online or at your local Radio Shack.
Hope that helps
Feb 15, 2010 | Pioneer VSX-D903S Receiver
I have a Yamaha TSX-130. Won't play CD when alarm set.
hi go to the alarm option in your system and diable the repeat option and enable play all it will work thank u
Aug 24, 2009 | Yamaha TSX-130BL Desktop Audio System ...
Static on fm radio stations
Since my system can be mounted on the wall I found a spot on the wsll about 5 feet from the floor to mount it and now I can get the fm stations.
Dec 26, 2008 | Audio Players & Recorders
19 people viewed this question
 Grubhead
Grubhead
