Question about Sharp AL 800 Copier
Sharp Al-800 Skewed Copies
The machine was fine one moment, then - puff - the gremlins took control ! It does copy - but has a fairly loud rythmic clicking sound (almost a "thump" ) and, although the paper comes out straight , the copy print comes out skewed/crooked on the page with a periodic black line that seems to coincide with the timing of the clicking sound. Any suggestions would be appreciated, thanks in advance. FYI - the toner and drum cartridges are reasonably new/young.
    Sergeant:
  • 329 Answers
One problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
Posted on Jun 12, 2008
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
May 03, 2011 | Sharp Office Equipment & Supplies
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
May 11, 2009 | Sharp AL 800 Copier
Machine over heated now the copies are black
Do the copies come out totally black or just dark???? Does the copiers scanning lamp turn "ON" when you go to make a copy? If you smell something burning, you may have paper wrapped around the upper fixing roller...
Apr 28, 2009 | Sharp AL 800 Copier
Loud clicking noice during copying
take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Feb 14, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 overheats after replacement of fuser and fans
Hello sir; that's a simple problem whayever you mention all the parts you replace are not necessary, if you can't reset H4,or H3 then you need to replace "THERMISTOR" that is the device to control the temperature, the parts #RDTCT0128FCZZ.
Feb 12, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
SHARP COPIER AL-1631
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
and/or
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
