Question about Fisher and Paykel GWL11 Top Load Washer
HI, I HAVE A GWL11 FISHER PAYKEL WASHER, THE PROBLEM IS , THE WASH COMES OUT DIRTIER THAN WHEN IT WENT IN, ANYBODY HAVE ANY SOLUTIONS? THANKS
  • 72 Answers
Possilbe fault 1, you have faulty seals and its leaking bearing oil . a picture is worth a thousand words
or possibly fault 2, your machine is dirty by using washing powders, always use liquid washing detergents like Cold Power or simliar - they are self-cleaning.
Posted on Sep 25, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Cold water valve?
Replace the inlet valve. This is a common fault easily fixed with a new valve.
Apr 07, 2017 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
105 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
