Question about Lexmark All-in-One Printer with PictBridge
Help When I scan a document there is a black line right in the middle of it ....how can I fix it
  • 48 Answers
Try cleaning the scanner glass with a soft cloth...
and then try...
what is the printer model u r using
Posted on Jun 18, 2008
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
Oct 05, 2009 | Canon DR 3080C Path-Through Scanner
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
Mar 13, 2009 | HP LaserJet 4345mfp Printer
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Scanning and faxing
clean the glass with soft cloth and smallest amount of water, rub hard to get off the small dots that cause the lines even if you can not see any
Oct 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Thick Black Line in Middle of Printed Document!
Your question might best be answered at the website below
http://www.canon.co.uk/Support/index.asp
They have technical support plus drivers and other odds and ends concerning your equipment
Feb 22, 2008 | Computers & Internet
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Lexmark All-in-One Printer with PictBridge Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
