Question about Kenmore 22422 Top Load Washer
My Kenmore model #22632100 wont drain. The door load switch is solidly in place as is the actuator. Should I hear a click if I put my ear next to the switch and actuate it by hand? How do I tell if if it's the switch, the pump or a clog in the drain lines? Thank you.
jsrock516
  • 5911 Answers
SOURCE: kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 17, 2008
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer spins but won't drain (model #110.20052993)
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Drain issue on front load Kenmore He3t
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
80 series kenmore washing machine will not drain or spijn
If the switch is good you should hear a click when door is opened. Another click just before it closes. Sometimes they just need adjusted, or the actuator is broken or needs adjusted. TThe door lid switch sounds like the culprit in this case. It affects both functions. How about a video? http://www.youtube.com/watch?v=rjFuQQbj3-8
Jan 06, 2013 | Washing Machines
2005 pontiac montana drivers door wont lock with remote but will lock from inside switch or with key on outside...it WILL unlock with remote as well as all other doors...
put your ear to the door and try to open it with the remote, if you hear it trying to open, then most likely you door lock actuator is bad and needs replacement. It may have disconnected itself from the door lock lever as well, but i suggest opening up the door panel to better ***** the situation. It all points to the actuator.
Aug 19, 2011 | Pontiac Montana Cars & Trucks
Thanks in advance, my washer fills with water but doesn`t spin. not any noise.
The safety interlock switch might be bad. That's a safety switch to prevent the machine from agitating or spinning while the door is open. Close the door slowly and listen for a click just before it is completely closed. If you don't hear it, then check the alignment of the door and its actuator. If you do hear a click but the machine doesn't start, then the switch may need replacement.
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2010 | Washing Machines
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore washer won't drain
Aug 09, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Freezer way too cold - ice cream hard as a rock
I have the same problem and from reading on the web I think I have found the problem. It is a bad Freezer Thermistor and they are very inexpensive. I am posting a link that can help you determine if this is the problem.
I found some service instructions for Kitchenaid side by side fridges with electronic control. Since both your fridge and KA's are made by Whirlpool, the instructions should apply. I learned something new, there are TWO thermistors! To download the instructions go to Service Matters Online click on technical reference, then next pge click on I accept, next page click on technical library [left sidebar], next page click on job aids [left sidebar], next page click on search job aids [upper middle of the page], next page type in refrigerator then click on search, next page click on KA side by side electronic control [KAR-10], next page click on the pdf symbol, then print out the document.
Feb 08, 2008 | Kenmore 72073 Top Freezer Refrigerator
Kenmore 22422 Top Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
