Question about Delta Plumbing
My bath tub drain delta number RP293 does not seal to keep the water in the tub. it did before. i tried to tighten by turning clockwise but it tightened with no more play but did not seal
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
You need a new stopper assembly. Call Delta Faucets and ask for a new stopper for free. They have been really easy to work with so far.
Posted on Sep 14, 2010
For a tub overflow washer (Part# PPC826-3) where should the "thick end" go - top or the bottom? Is pasting a little silicone recommended on it so that it has a better seal after I tighten the screw?
The thicker end goes up because of the sloped end of the bathtub. You should not need to apply any sealant - the gasket is compressed as the screw is tightened.
Dec 06, 2016 | Plumbing
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
My Delta type kitchen sink handle is loose and keeps shutting water off. I have to turn it up a lot to keep it going. I could remove Red / Blue plug and do not know what to do beyond to tighten it?
Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
Oct 12, 2010 | Plumbing
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
I have a Delta push down bathtub drain stop, but it is worn and does not stop the water. It does not unscrew as far as I can see how do I get it apart without removing the tube which I can not do?
Lift and Turn:
Toe Tap:
Apr 06, 2010 | Delta T13420 Chrome Classic Single Handle...
Does not drain properly . It leaks through the door.
The leaks through the door problem is caused by an overfilled tub. Remember, these dishwashers aren't bath tubs. Those seals are only designed to keep water from splashing out, not for completely filling the dishwasher with water. These problems are both caused by the slow drain, and can usually be fixed quite easily by removing and cleaning the strainer screen and using a wet/dry shop vacuum to **** out the debris underneath. If your shopvac is powerful enough it will also clean out the water pump.
Replace the screen and try again.
Mar 05, 2010 | GE Nautilus 24" Built-in Dishwasher
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Nov 25, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
Bath tub faucet will only run hot. Just started
It sounds like the seals are going bad. Moen is probably rebuildable. You can go to a Menards and ask if they have the replacement guts for your particular model.
Nov 17, 2009 | Home
Leaking bath drain
Remove the hair strainer or pop up drain assembly if so equiped and using a basin wrench or two crossed screwdrivers unscrew the drain basket and remove from the tub. Clean the tub and the back side of the basket and apply a generous bead of plumbers putty to the backside of the basket and reinstall. Tighten it down squeezing out excess putty, wipe off excess putty and you are done.
Some people use silicone sealer in lieu of plumbers putty and it will work fine but is messier in my opinion and makes dis-assembly harder.
Oct 14, 2009 | Plumbing
Plumbing Logo
326 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
