Question about Kenmore Dryers
I have a kenmore dryer model # 86182100 i need to replace the drum belt and pulley, how do i do it?
  • 1314 Answers
SOURCE: dryer drum does not turn
how about the idler pully that keeps the belt tight did you see it in there has to be there look if its is ther try to turn the drum by hand a foregin object could be jaming the tub im here to help get back and let me know
Posted on Dec 30, 2007
docjohn174
  • 943 Answers
SOURCE: Kenmore Series 80 electric dryer
hi. i will send you to .repair clinic. go to dryers and belt diagrams. sorry i cant send you one. if you have any trouble, get back to me the appliance doc
Posted on Oct 02, 2008
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
nnesmith
  • 162 Answers
SOURCE: How do I replace the dryer belt on a maytag dryer
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Posted on Jan 30, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Tip
Kenmore Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Kenmore models starting with 110 or C110 with a removable back use this:
Style: Flat with ribs
Installation Tips: Ribs against drum
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Installation Tips: Ribs face toward drum
on Mar 06, 2010 | Dryers
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
How do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Apr 26, 2010 | Kenmore 62602 Electric Dryer
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
Drum won't rotate. How do I replace the belt?
should be able to get at it from back or bottom and just unbolt the pulley and place new belt and pulley on at same time
Oct 01, 2009 | Dryers
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
Reassemble dryer
to replace and go back together you need 1st put in the drum with the felt at the back, slide belt around drum, hook the idler into the **** on bottom by motor, pull idler back, loop belt though idler and over motor pulley ,,,,, it takes time if never did it before but can be done in about 10 minutes.
Larry
Nov 24, 2008 | Kenmore 62602 Electric Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
