Question about Wild Planet Room Gear Atm Safe Bank
I cannot reset the balance to "0". The lowest amount I have been able to set it is $8.00. The ATM card gets stuck in the machine and is hard to remove.
Go to www.wildplanet.com/help/instructions/ATMSafe.pdf
Posted on Jul 28, 2011
How to program a blank atm card
You are welcome to our online hacking services.We encourage you to try this life transforming deal and be rich forever without any trace. OUR SERVICES We are professional carding team with a large ring around the globe.With over 2 million ATM infected with our malware and skimmers,we can grab card data which include track 1 and track 2 with the card pin.We in turn clone this cards using the grabbed data into real ATM cards which can be used to withdraw at the ATM or swiped at stores and POS.We sell these cards to all our customers and interested buyers worlwide,the card has a daily withdrawal limit of $25,000 on ATM and $10,000 spending limit in stores.Contact us now at (excelatmhackers@outlook.com)
Jan 08, 2017 | Toys
How can I know my balance on my checking account
Call your bank. The number is on your ATM card. You can also check it by going to a ATM center and use your card to check your balance.
Dec 16, 2013 | Computers & Internet
Start over with money
Here is a link to the PDF Instruction Manual. I have also copied the instructions for resting the amount to zero:
To Reset Account To Zero:
Turn on the ATM Safe by inserting your ATM card into the slot and entering your PIN code.
• Press and hold the 1, 2, and 3 keys (Fig 8).
• The display will read, "Reset to zero?"
• Release the 1, 2, and 3 keys and then press the "e" key.
If the electronic functions of ATM Safe stops working, open the battery door
(see instructions "To Install Batteries") and locate the RESET button above the batteries.
Press once to reset. Note: Account balance will not reset to zero.
Jan 25, 2011 | Wild Planet Room Gear Atm Safe Bank
Forgot PIN
Answer: 1. Insert your ATM card into the slot with the holes pointing down
2. The auto teller will ask you to enter your PIN code.
3. Press and hold keys 1 and 2 until the screen reads, "Reset PIN."
4. Enter a new four-digit PIN code, and then press the "e" key.
5. Enter your new PIN code again to confirm. Press the "e" key.
6. The ATM Safe will restart.
Aug 08, 2010 | Wild Planet Room Gear Atm Safe Bank
I lost my ATM card in the washer and was not unable to find it. Now I notice a short grinding sound every once in a while when the machine goes into a fast spin cycle. Obviously, I think it is the ATM card...
What a bummer.... pull the agitator up... it should snap off.. and if you're lucky your card will be lodged underneath....otherwise you'll need to pull this machine apart . you may even need to pull the inner drum loose to access. Start with the simple...pull the agitator..
Oct 17, 2009 | Washing Machines
I need a java source code file that is just like a ATM machine which saves the transactions...for example if you have withdrawn $1000 from your atm account and you have $5000 dollars...it would save the...
/* Program to Find whether number is Prime or Not. */
class PrimeNo{
public static void main(String args[]){
int num = Integer.parseInt(args[0]);
int flag=0;
for(int i=2;i<num;i++){
if(num%i==0)
System.out.println(num+" is not a Prime Number");
flag = 1;
break;
if(flag==0)
System.out.println(num+" is a Prime Number");
May 16, 2009 | Microsoft Windows XP Professional With...
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
Dec 25, 2008 | Blue Microphones Blue Hat Little Shots...
SUMMIT PRODUCTS YOUniverse Deluxe ATM Bank Machine
We had the same issue -- the name could be reset, but not the pin could not.
Finally, I realzed that when it is reset by using the reset button or the batteries, the PIN is reset to the factory default of 1234. Don't try using your old pin at this point -- enter 1234 as the pin.
Once you have the bank working again, theoretically you can reset your pin to whatever you like by hitting enter twice. I say theoretically because we're sticking with the factory default for now.
Hope this helps.
Nov 07, 2008 | Summit Electronic Money Jar
Wild Planet Room Gear Atm Safe Bank Logo
222 people viewed this question
Top Wild Planet Toys Experts
Robert Welain
Robert Welain
robsandra
robsandra
Level 1 Expert
Are you a Wild Planet Toy Expert? Answer questions, earn points and help others
