Tip & How-To about Computers & Internet
If you have two partitions on the hard disk and no other drives installed, the DVD drive should be drive E:. If there are more drives, disconnect them. When you boot the Startup, you should see it ask whether to start with CD-ROM support or not. Of course, at this stage, the DVD drive should behave like a CD-ROM. You should see it load the CD-ROM driver successfully.If it still doesn’t happen, see which applies. Else Click on Start>Run>type regedt32 in the run dialog box and press Enter key. Registry editor will be opened. Backup your registry by going to File>Export and save the file with any name. Now on the left side, navigate to the location HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control >Class> Click on {4D36E965-E325-11CE-BFC1-08002BE10318} At right side delete these files if you find(found) it upper filters,lower filters,upper filters.bak,lower filters.bak and then restart your ComputerHope this will help you.All the Best!
